filament dryer
skylab9999
(@skylab9999)
filament dryer
I wanted  a filament dryer but decided not to buy a expensive one and decided to do this
bought a wine fridge used  $75.00n used
bought a dehydrator            $25.00  used
3 lights                                    $20.00
removed the control box from the wine fridge  and used the power leads to connect to my lighting consisting of two vertical lights and one for the overhead light
3d printed a box to contain the power supply for the thermometer and the overhead light
placed the dehydrator in the bottom
and you can  see the finished product.
Posted : 28/09/2025 1:12 am
RE: filament dryer
Do you use incandescent lamps which act as heaters, and control them via a thermostat (not just thermometer)? In my understanding you need to heat the air inside the box, to ensure that the filament releases the water that has already bound to its matrix. Just surrounding the filament with dry but cool air is not effective.
Posted : 28/09/2025 7:18 pm
skylab9999
(@skylab9999)
RE: filament dryer
The lamp in the overhead box is a led corn roll type screw in bulb, the two vertical bulbs are just  fluorescents,  I think there is no appreciable heat coming from the bulbs, i set the dehydrator to its lowest setting and that's where  the 119 Fahrenheit and the 10% humidity is coming from
Posted : 28/09/2025 10:06 pm
