Fast, robust visual diff for 3d files
Bruce Lucas
(@bruce-lucas)
While generating 3d models for printing, I sometimes need to compare two files to see what’s changed. I couldn’t find a satisfactory tool for doing this, so I made one. Maybe other 3d printers will find it useful.
Download at: https://github.com/bdlucas1/diff3d
Here's an example. Most of the lens clamp is unchanged and is displayed in gray, while the differing parts are displayed in red for one file and green for the other file: in the red file the diameter is smaller, while in the green file the base is longer, and the threaded hole has moved.
Opublikowany : 13/12/2024 4:16 pm
3 ludzie polubili
Bruce Lucas
(@bruce-lucas)
RE: Fast, robust visual diff for 3d files
I've released a new version, 0.2.0. You can use pip install --upgrade diff3d to upgrade it.
This new version introduces an alignment feature, enabled using the --align flag, that attempts to align major features that the two meshes have in common, thus displaying a minimal set of diffs.
It also fixes a problem with a missing dll that you might have encountered in Windows.
Tested installation instructions for Windows, MacOS, and Linux are included at https://github.com/bdlucas1/diff3d , in case you've had any trouble installing it.
Opublikowany : 20/12/2024 6:32 pm
1 ludzie polubili
Bruce Lucas
(@bruce-lucas)
I've released a new version, 0.3.0. You can use pip install --upgrade diff3d to upgrade it.
This new version introduces a color animation feature: press the "a" key to briefly flash the colored areas, making them easier to spot.
See   https://github.com/bdlucas1/diff3d for full details.
Opublikowany : 23/12/2024 1:15 pm
1 ludzie polubili
JanLM
(@janlm)
Bruce, thank you for taking the time to develop and share your program with us.
Jan
Opublikowany : 24/12/2024 2:00 pm
1 ludzie polubili
