Drying desiccant
Pagina 1 / 2
scott.b47
(@scott-b47)
Drying desiccant
I have a food dehydrator that I purchased for drying filament and desiccant for reuse (I have the blue color-changing variety), but I have yet to find the ideal container to hold the desiccant while drying. Generally I store my used desiccant in an empty quart paint can, but that has little surface area. I tried printing myself some small trays, but what I can easily print turned out to be a little too small. I also tried some baking sheets, but those ended up with me spilling desiccant all over the place.
My dehydrator is this one, https://www.amazon.com/gp/product/B074P6MGFR/ , which provides quite a bit of space.
Ideally I'd find some kind of large rectangular mesh container that I could put in it.
What are other folks doing?
Scott
Postato : 06/07/2019 2:19 am
Sembazuru
(@sembazuru)
RE: Drying desiccant
I'm about to start needing to dry my dessicant, and will be drying it loose. What I'm thinking of using is a flat (or nearly flat, not the conical type) fine mesh kitchen strainer that I can remove the long handle from to fit inside my food dehydrator (I have one of the round ones similar to the PrintDry base but with regular food trays that I've cut to fit spools). Maybe an inexpensive strainer with a plastic body like this one: https://www.amazon.com/Chef-Craft-21389-Stainless-Strainer/dp/B001WYPGZ2/
Just my untested thoughts.
See my (limited) designs on:
Postato : 06/07/2019 5:23 am
Heh. Got a PrintDry for Christmas. I just dump the desiccant packets in the top tray while I dry filament in the bottom. Nothing fancy.
Postato : 06/07/2019 6:04 am
catfood
(@catfood)
If you're dealing with loose desiccant pellets, you might try using a small nylon bag.  I've used ones I get from a local homebrew supply store with are about 6" x 8".  They're very fine mesh, and are designed for holding brewing ingredients during boiling and fermentation, so they can take the heat.
Postato : 06/07/2019 6:41 am
1 persone hanno apprezzato
Posted by: Catfood
If you're dealing with loose desiccant pellets [...]
Must confess, I assumed packets. Didn't even think about the loose pellets. Good tip.
Postato : 06/07/2019 6:55 am
Sink
 Sink
(@sink)
Stuff I get in Germany. Put it into bags, see pic .. and into containers with filament..
Dry in the over when required .. change of color to dark .. and then repeat .. Been using the same container for almost 2 years
https://www.amazon.de/KnePo-Kunststofftechnik-regenerierbar-Trockenmittel-Indikator/dp/B07DY2WMPG/
Attachment removed
Postato : 06/07/2019 9:18 am
Sink
 Sink
(@sink)
Containers ..
Attachment removed
Postato : 06/07/2019 9:24 am
Sink
 Sink
(@sink)
Happy, safe, and dry
Attachment removed
Postato : 06/07/2019 9:31 am
scott.b47
(@scott-b47)
Posted by: Catfood
Yeah, I think this may be what I'm looking for. I'll try looking for "nylon strainer bag" or similar. If I could get a big enough bag that would hold about a quart of desiccant pellets, or two bags that would hold half that, I think I'd be good.
I should have mentioned that I'm perfectly happy with my solution for holding desiccant along with the filament. I use "inside spool desiccant container" on Thingiverse. It's just when it comes time to recharge the desiccant that I need a good solution.
Postato : 06/07/2019 3:58 pm
And just remember nylon sucks up moisture like nothing else - so be sure to dry it out before you use it for holding desiccant ... lol.
As for containers, these have water tight seals and aren't too expensive.
https://www.amazon.com/IRIS-USA-Inc-WeatherShield-Storage/dp/B07BMHVTC8
Questo post è stato modificato 6 years fa 2 tempo da --
Postato : 06/07/2019 8:00 pm
Sembazuru
(@sembazuru)
Posted by: scott.b47
Posted by: Catfood
I use the same desiccant containers from Thingiverse. 😀 To follow up with my post above about using a strainer and cutting off the handle to fit the dehydrator, I think I may have found a better solution surfing around in Amazon... A flour sieve that doesn't have handles. This is a 6" with a 40 mesh for 11USD: https://www.amazon.com/dp/B07DBB5RS4/ref=psdc_289726_t1_B0173ASBV4
The advantage that I conceptualize (so I may be way off) is an open topped container allows you to monitor the color of the desiccant indicators while drying (a mesh bag is harder to see through) and makes it easy to stir the beads while cooking drying. Could probably go as large as 18 mesh for the silica beads that I have (mesh to particle size chart), but I'm not sure how much more looking I feel like doing...
I just put one on order and if I remember about this thread I'll report back on my results once I've used it.
Postato : 06/07/2019 8:30 pm
scott.b47
(@scott-b47)
Oh I like the idea of those. I do think 6" diameter may be a little on the small side though. The ones I printed myself were approximately 4" by 6" and they don't hold much desiccant at all.
You have given me some great ideas to look for though. If I could find a 10" or 12" diameter in the right mesh size, I might just see about ordering one.
Postato : 06/07/2019 9:02 pm
osbock
(@osbock)
BTW, I just found these at IKEA:
https://www.ikea.com/us/en/catalog/products/S79276760/
$9.99 and perfect for most spools and the MMU rollers.
Just pop a festo or 3d printed bowden coupler on there and you are good to go. Even fits the wide prusament spools.
Will also hold 2 regular spools or one wide and one regular without the rollers for storage.
Pros over IRIS containers: better size and shape, stands up the right way for feeding filament.
Con: the latches may not last as long.
Questo post è stato modificato 6 years fa da osbock
Postato : 06/07/2019 9:09 pm
scott.b47
(@scott-b47)
Posted the drying trays I designed, https://www.thingiverse.com/thing:3733030/files , the ones that came out too small (4" by 6") and didn't hold enough desiccant to be particularly useful, just in case they turn out to be useful to someone.
Postato : 06/07/2019 9:52 pm
osbock
(@osbock)
  • I like what you did with the outing spout there!
Postato : 07/07/2019 12:10 am
Sembazuru
(@sembazuru)
I got my flour sieve today. Here it is in the dehydrator (the sieve is 6" in diameter):
I poured two "inside spool desiccant container"s worth of desiccant into it and it just covered the bottom. (The first container was definately saturated, but the second container was only partially saturated. That's why the dark blue/green beads are on the bottom.)
Here it is with the dehydrator closed up just after I turned it on. (The wires going into the dehydrator are thermocouples because I don't trust the stability and accuracy of the temperature control yet. I just happened to have an Arduino setup with 4 thermocouples and a display for each that was left over as a demonstration circuit for a SPI multiplexer that I designed.) The temperature was set to 65°C based on the chart that I printed from some filament vendor's website (I forget which one).
After a couple hours I checked on it to make sure the temperatures were good (they were, good little El-Cheapo brand dehydrator), and I saw that the silica beads were back to their amber "thirsty" state. But I didn't have time then to take pictures, shut things down, and put the desiccant away. Much later (about 5hrs 12minutes from the start) I returned again and took pictures. The timer is the highlighted line on my watch:
(Drat. Sorry the picture is sideways... Apparently this forum ignores the rotation meta data in images...)
My conclusion: For loose desiccant beads these all-metal flour sifter rings are great. Many that I found on Amazon were stupidly expensive ($50USD and up), but this one (linked in my message above) was only about $11USD. I estimate I could proabably put a good dozen of the "inside spool desiccant container"s worth of desiccant in it without problem and not get desiccant beads down inside my dehydrator.
Postato : 08/07/2019 5:45 am
bob
 bob
(@bob)
I use airtight lock&lock containers.  I put a small aluminum pan in the bottom and fill it with color indicating Dry-Dry (Amazon). I sit a piece of suspended ceiling egg crate light grid on the pan.  Holds two spools of filament. They stack nicely and allow you to see color of filament and color of desiccant.
Postato : 21/07/2019 10:59 pm
RAH1
 RAH1
(@rah1)
Drying Filament -- Was Drying desiccant
All,
Interesting conversation.  I like the idea of using a 2 spool dehydrator for spools and then putting them into dry boxes with desiccant.  The Matter Hackers one seems like overkill.  I would need too many for the MMU2S to use them as dry boxes.
I already have some Ikea Samla boxes which hold 3 to 4 spools each depending on spool size, (to which I sealed and added locking clips and covered desiccant trays.  See picture 1).  I also got some 3 spool Sterlite boxes (that already have seals and locks, pictures 2 and 3), to contain my 9 auto rewinders for the MMU2S.  My question is which dehydrator will work out the best?
RAH
FYI...
Matter Hackers drying recommendations (picture 4):
I am the inveterate tinkerer. I can tink up most anything.
Postato : 29/07/2019 2:17 am
RAH1
 RAH1
(@rah1)
Posted by: Sembazuru
Sembazuru,
I like the round flour strainers as a desiccant drying holder.  I would only fill them to about one layer deep to dry out desiccant.  They would dry so much faster.
RAH
Postato : 29/07/2019 2:21 am
RAH1
 RAH1
(@rah1)
All,
My question is which dehydrator would you recommend? Or at least which features are important for a dehydrator?
Thanks,
RAH
Postato : 31/07/2019 4:25 am
Pagina 1 / 2
