double-sided-powder-coated-pa-nylon-satin-spring-steel-sheet - is this an upcoming product?
John
 John
(@john-6)
The other day I can across this product in a Prusa web page - but now it directs to https://www.prusa3d.com/product/double-sided-powder-coated-pa-nylon-satin-spring-steel-sheet/ and doesn't appear to be available as a web page any ore
I still see the the search results in google but no longer the page in question. I wonder I this was a mistake posting of a new product.
Here is some text from google search
"Double-sided Powder-coated PA Nylon Satin Spring Steel Sheet for the Original Prusa i3 MK3/S/+ and MK2.5/S. MK3S MK3 MK2.5S MK2.5 MK3S+ Not compatible with MK2S MMU2S CW1 SL1 MINI MINI+ SL1S CW1S MK2 MMU2 MMU1 Enclosure $39.99 OVERVIEW: The MK52 heatbed has embedded high Curie temperature magnets."
maybe I wrong but I hope it is a new release
i3 Mk3 [aug 2018] upgrade>>> i3MK3/S+[Dec 2023]
Posted : 25/07/2022 3:35 am
John
 John
(@john-6)
This sounded like a really needed new product. So I would be interested if any one had any info on an upcoming Prusa  nylon spring sheet
Posted : 30/07/2022 1:53 am
adesir
(@adesir)
It's in the news here:
Mes modeles publics
Posted : 30/07/2022 4:35 am
John
 John
(@john-6)
RE: double-sided-powder-coated-pa-nylon-satin-spring-steel-sheet - is this an upcoming product?
@adesir - thanks
Posted : 30/07/2022 4:40 am
jsw
 jsw
(@jsw)
Googling the above text comes up with this link which appears to be the currently-available satin sheet.
https://kiwi3d.co.nz/product/prusa-powder-coated-pei/
Posted : 30/07/2022 5:15 am
John
 John
(@john-6)
Posted by: @jsw
I think Prusa may have inadvertently published the page for a short while  then removed it. Regardless I am very happy to see it is a product.
Posted : 30/07/2022 5:18 am
Artur5
(@artur5)
I'll order one of these as soon as they're available.
FR4/Garolite plates are 'usable' for PA but  far from great..
This post was modified 4 years ago by Artur5
Posted : 30/07/2022 7:02 am
John
 John
(@john-6)
Posted by: @artur5
My prototype musical instrument is now at the stage I want to swap out some pla for polyamide. So I will definitely be getting one after using   glue on builders tape.  I also tried geckotek and found it unsatisfactory for nylon , and everything else to be honest. If the new Prusa sheet works as well as the satin sheet I will have no complaints.
Posted : 30/07/2022 8:24 am
