					                		Could Static discharge fry usb port? - General discussion, announcements and releases                                    </title>
                <link>https://forum.prusa3d.com/forum/english-forum-general-discussion-announcements-and-releases/could-static-discharge-fry-usb-port/</link>
                <lastBuildDate>Fri, 10 Apr 2026 20:42:14 +0000</lastBuildDate>
                        <title>RE: Could Static discharge fry usb port?</title>
                        <link>https://forum.prusa3d.com/forum/english-forum-general-discussion-announcements-and-releases/could-static-discharge-fry-usb-port/#post-732866</link>
                        <pubDate>Thu, 16 Jan 2025 18:26:15 +0000</pubDate>
                        <description><![CDATA[Possibly is best answer I can give - static can potentially be sending several hundred to thousands of volts through components designed to handle around 5v - it is likely from a single disc...]]></description>
                        <content:encoded><![CDATA[<p>Possibly is best answer I can give - static can potentially be sending several hundred to thousands of volts through components designed to handle around 5v - it is likely from a single discharge it just fried the USB input (the physically connector is liable to be OK)</p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/english-forum-general-discussion-announcements-and-releases/">General discussion, announcements and releases</category>                        <dc:creator>Ken</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/english-forum-general-discussion-announcements-and-releases/could-static-discharge-fry-usb-port/#post-732866</guid>
                        <link>https://forum.prusa3d.com/forum/english-forum-general-discussion-announcements-and-releases/could-static-discharge-fry-usb-port/#post-732778</link>
                        <pubDate>Wed, 15 Jan 2025 22:23:34 +0000</pubDate>
                        <description><![CDATA[You may need a new LCD display]]></description>
                        <content:encoded><![CDATA[<p>You may need a new LCD display</p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/english-forum-general-discussion-announcements-and-releases/">General discussion, announcements and releases</category>                        <dc:creator>FoxRun3D</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/english-forum-general-discussion-announcements-and-releases/could-static-discharge-fry-usb-port/#post-732778</guid>
                        <link>https://forum.prusa3d.com/forum/english-forum-general-discussion-announcements-and-releases/could-static-discharge-fry-usb-port/#post-732765</link>
                        <pubDate>Wed, 15 Jan 2025 20:28:30 +0000</pubDate>
                        <description><![CDATA[I havent tried accessing via ethernet yet. I was going to try a new flash drive first and than assess. If it is indeed the usb port will I just have to re solder a port into the board or is ...]]></description>
                        <content:encoded><![CDATA[<p>I havent tried accessing via ethernet yet. I was going to try a new flash drive first and than assess. If it is indeed the usb port will I just have to re solder a port into the board or is there a possibility of that discharge affecting more beyond it?</p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/english-forum-general-discussion-announcements-and-releases/">General discussion, announcements and releases</category>                        <dc:creator>Attack</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/english-forum-general-discussion-announcements-and-releases/could-static-discharge-fry-usb-port/#post-732765</guid>
                        <link>https://forum.prusa3d.com/forum/english-forum-general-discussion-announcements-and-releases/could-static-discharge-fry-usb-port/#post-732758</link>
                        <pubDate>Wed, 15 Jan 2025 18:57:53 +0000</pubDate>
                        <description><![CDATA[I&#039;m afraid so, can you access printer via network?]]></description>
                        <content:encoded><![CDATA[<p>I'm afraid so, can you access printer via network?</p>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/english-forum-general-discussion-announcements-and-releases/could-static-discharge-fry-usb-port/#post-732758</guid>
                        <title>Could Static discharge fry usb port?</title>
                        <link>https://forum.prusa3d.com/forum/english-forum-general-discussion-announcements-and-releases/could-static-discharge-fry-usb-port/#post-732704</link>
                        <pubDate>Wed, 15 Jan 2025 05:12:28 +0000</pubDate>
                        <description><![CDATA[😫 I went to plug in a flash drive and got a pretty good shock. Now mini wont recognize flash drive. Tried a couple other flash drives I had to no avail. Any recommendations?]]></description>
                        <content:encoded><![CDATA[<p> 😫 I went to plug in a flash drive and got a pretty good shock. Now mini wont recognize flash drive. Tried a couple other flash drives I had to no avail. Any recommendations?</p>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/english-forum-general-discussion-announcements-and-releases/could-static-discharge-fry-usb-port/#post-732704</guid>
