Clear filament for pool stuff
Magst
(@magst)
I wanna print some stuff to be used in a pool (parts need to be as clear/transparent as possible) and have been reading what I could find but still isn’t sure what filament is the best.
ASA should be pretty uv and chemical resistant (for chlorine) and is recommended by some.
PETG should also be uv resistant and strong and is available as transparent filament.
PC is also uv resistant and strong and available as transparent.
PMMA is apparently the most transparent but can crack/fracture.
I won’t be able to sand and polish the parts as they will be hollow. Are there others that are better suited?
Sorry if it is a trivial question or if it has been asked before, but I haven’t been able to find the answer.
Opublikowany : 20/07/2022 2:04 pm
jsw
 jsw
(@jsw)
RE: Clear filament for pool stuff
You will not be able to get truly transparent parts out of a common FDM 3d printer, despite a few postings on the web claiming that photos of crystal-clear parts were indeed done on such printers.
I have yet to actually see, as in hold in my hand, or even see photos of from someone I know and trust, any parts that truly exhibit glass-like transparency.
If you do a search here for threads on transparent printing (hint: use Google or DDG instead of the forum search) you will see examples of things that users here printed, which are indeed clear enough to show things such as written text through the object, plus links to the purported crystal-clear prints.
The photo below is typical of what degree of translucency you can expect from so-called transparent filaments, this in particular being PETg, without very tedious post-processing.  These are windows for a model railroad building, just a few mm thick, 100% infill, and show very little detail of what's behind them (which is a good thing for this particular model).
As for a pool environment, PLA is out as it's known to deform in hot summer sunlight.  I would also question that 3d printing is the correct tool for the job for any piece that needs to be truly water-tight and/or hold up under water pressure.  We have a transparent 'sight glass' in our pool's backwash line, and it's a piece of transparent pipe from the hardware store.
I recently printed the bracket (and other parts) for a pool alarm sensor and I did this using white (absorbs heat less) ABS.
Opublikowany : 20/07/2022 3:27 pm
Magst
(@magst)
Thanks jsw,
I also doubt that I can get it truly transparent prints although some have had success with polysmooth:  (probably not suitable for pool/outdoor use)
or with clear PETG: https://www.printables.com/model/15310-how-to-print-glass#_ga=2.173085419.931490844.1657914875-1801670987.1598897847
However, less can also do. I just wanted to know if it is a totally waste of time of if anybody have any experience/opinion about which filament type would be best to experiment with.
By the way, I read that white ABS turns yellow over time in the sun and that ASA would be better.
Best, Magst
Opublikowany : 20/07/2022 3:49 pm
RandyM9
(@randym9)
I’ve printed some pool parts in white PETG and they are holding up well in the pool water which is chlorinated using a swcg.
My parts don’t need to be water tight or hold water, or hold pressure; they just need to be able to survive being submerged in pool water and exposed to the sun.
Keep us posted on your progress.
Cheers
Opublikowany : 21/07/2022 3:13 am
jsw
 jsw
(@jsw)
I do know that some white ABS, as it comes from the factory, is not as bright a white as many white PLA or PETg filaments.
I'm currently doing a print in MG Chemicals white ABS, and I would call it more 'paper white', as opposed to 'zinc oxide white' as Hatchbox PLA is.
Opublikowany : 21/07/2022 3:28 am
yahbluez
(@yahbluez)
Overture has some transparent PETG:
https://www.amazon.de/gp/product/B08X6YK3SQ/ref=ppx_yo_dt_b_asin_title_o00_s00?ie=UTF8&th=1
Opublikowany : 21/07/2022 9:11 am
Magst
(@magst)
Yes, thats the filament they used in the second link in my first post. Have you tried it?
Opublikowany : 23/07/2022 6:24 pm
yahbluez
(@yahbluez)
I got a spool yesterday but can't test it during the next days. I have already tested a China PETG.
https://www.printables.com/model/10131-detailed-calibration-tower/comments/324043#
It's not that bad but far away from this pictures of clear fdm prints. (I don't even believe this pictures are true)
https://imgur.com/tSJJOWg
The overture was cheaper and comes in a sealed silver bag. Did not open it, has to wait.
Opublikowany : 23/07/2022 7:18 pm
