Can't publish a draft
Rosie3D
(@rosie3d)
It's not throwing any errors, I simply move the slider from Draft to Published and click Publish Now.  The button clicks and it in half a second the page reloads and nothing has happened.
Any thoughts?
Respondido : 03/02/2020 6:31 pm
 Anónimo
RE: Can't publish a draft
Posted by: @jerosenwald
Any thoughts?
Hello,
please try it again now. There was a bug in the print tags validation. Probably you had an unallowed character in the hashtag. If it happens again, please let me know.
Respondido : 04/02/2020 7:33 am
Rosie3D
(@rosie3d)
@ondrej-stritesky
Nope, no good.  Same behavior
Respondido : 14/02/2020 5:59 pm
 Anónimo
@jerosenwald
You are right. That is probably another problem. We are working fix. Thank you for reporting. I will let you know soon.
Respondido : 19/02/2020 3:01 pm
Rods
 Rods
(@rods)
i have the same problem...
Respondido : 29/05/2020 2:32 am
Jav.BR
(@jav-br)
I am also seeing the same exact behavior, been trying to publish my first print for a few days
At first it would also give me a warning of "are you sure you want to leave the page without saving work" even though I had just saved draft. That's not happening anymore, although I still can;t publish as described above. I even deleted and recreated the whole print.
One note, in case it's useful in troubleshooting, is that I added two remixes in there, as I used parts from two other separate prints...
Respondido : 09/10/2020 4:26 pm
Jav.BR
(@jav-br)
did try removing one of the remixes, no effect
Respondido : 09/10/2020 5:37 pm
Jav.BR
(@jav-br)
I was using firefox and managed to do it in chrome, but I don;t think that was the issue. It seems that, while I had selected the license when saving draft, the selection disappeared when trying to publish. A validation error message showed up under the dropdown, but I couldn;t see it after hitting publish now as it did not focus down on it or show a error message at the top of the page. I noticed it from scrolling down, selected the license, and it worked
Respondido : 09/10/2020 6:04 pm
gloda
(@gloda)
I had the same problem today. The horizontal load bar at the top of the page that normally shows save progress did not appear. In the end, clikcing the "Close" button took me back to my profile page without additional warnings. Everything but the print files was deleted.
Possible culprit: in the print instructions, inside an ul list, I had an li tag that was closed but not opened. My second attempt at saving a draft worked, but I'm not sure if this change made the difference.
Respondido : 16/01/2021 8:28 am
Jason_M
(@jason_m)
i have the exact same issue today.
i wasn't even trying to save a draft. it defaulted to a draft. and now i cant publish it.
Respondido : 30/03/2022 2:43 am
(@-6)
Sadly Prusa is having problems with everything from their website to their model database to their current printer quality.
Best to avoid anything Prusa until they improve their business model.
Respondido : 30/03/2022 11:21 am
funCoolio
(@funcoolio)
@dontbuyprusa: we generally say: "you did it in slices" when too much is too much.
DISCLAIMER:
I am not and will never be an employee of Prusa Research unless they offer me 100K € gross per year. I have friends who built the printer starting from a wooden frame ... that says a lot.
1+1=10 - take a look at my disgusting and useless models
Respondido : 30/03/2022 11:58 am
(@-6)
@funcoolio, "you did it in slices"
Respondido : 30/03/2022 12:03 pm
