Cancel one particular object in a multiple object print?
Shijune01
(@shijune01)
Hello Everybody,
I´d like to ask if it is possible to do the subject question. Is it possible to cancel one particular object in a multiple object print?
Let´s say I´m printing four instances of one object (for example a cylinder with a narrow base), during the print one of the instances get loose and felt. Is there any way to "cancel" the print for that object (let´s say #1) but contunuing with the remaining ones?
If that is not currently possible, do you think could be a possible feature request?
Thanks in advance and regards.
snaptube.cam/https://9apps.cam/
Publié : 30/05/2021 10:51 pm
riyadc
(@riyadc)
RE: Cancel one particular object in a multiple object print?
I dont think it is possible if you're printing from the SD card as the gcode would need to be modified to cancel one object (Maybe its possible I'm not sure, I dont have a Prusa i3 yet).
But if you are using octoprint to send the print to the printer you can use the following plugin https://plugins.octoprint.org/plugins/cancelobject/ and it works with PrusaSlicer/Cura/Slic3r.
Publié : 31/05/2021 12:18 am
1 personnes ont aimé
Dan Rogers
(@dan-rogers)
In Octoprint there is a cancel objects add in that lets you do this
Publié : 31/05/2021 1:24 am
