Can I pause a print?
garryp4
(@garryp4)
Is it possible to pause a print then restart it? I want to make a part that will need a support part way thru the print. If I can pause the print, I can put something on a lower section then restart it. When the part is done I can then remove what I added as the support.
Veröffentlicht : 31/12/2022 6:45 pm
3Delight
(@3delight)
Moderator Moderator
RE: Can I pause a print?
It would help if you gave more details:
1) What model Prusa Printer do you have?
2) What slicer are you using?
The support technique you suggest is unreliable for a number of reasons, the support would have to be accurate to about a 10th of a mm, it would need to be held still while printing,  it would require precise placement.
Veröffentlicht : 31/12/2022 6:55 pm
Pause function for Marlin compatible printers - see here:
https://marlinfw.org/docs/gcode/M025.html
Prusa here:
https://reprap.org/wiki/G-code#M601:_Pause_print
Reprap see here:
https://reprap.org/wiki/G-code#M226:_G-code_Initiated_Pause
or:
wbr,
Karl
Veröffentlicht : 31/12/2022 7:53 pm
