Best filament you have tired?
Pagina 1 / 2
muo
 muo
(@muo)
just ordered some Prusamint PETG but besides that i am thinking of getting some other filament, what are some good ones you guys have tried?
i am debating between MatterHacker Pla maby glow in the dark and regular or HatchBox Pla. Are the 2 options any good?
which site/place are good to get pla/petg/etc....?
Questa discussione è stata modificata 5 years fa da muo
Postato : 20/09/2019 11:52 pm
locktec hanno apprezzato
RE: Best filament you have tired?
What are you printing? Do you need good finish? Part strength? Temperature resistance?
Postato : 21/09/2019 1:44 am
RAH1
 RAH1
(@rah1)
Posted by: @bobstro
Bob as usual you ask a lot of good questions.  I would also ask what colors are needed.  Some colors are only available from some vendors.  It's a smaller playing field if you need a specific color.  Also, Are you comparing only PETGs?  Or are you looking for PLAs, ASA, ABS, PLU, etc.
There are way more answers to the original question than just one vendor over another.
Robin
Questo post è stato modificato 5 years fa da RAH1
I am the inveterate tinkerer. I can tink up most anything.
Postato : 21/09/2019 2:19 am
RAH1
 RAH1
(@rah1)
Mop,
It might be easier to agree on the vendors, filament types, and colors to avoid.  I have a few that I would NEVER use again for anything.  That might be a shorter list.  😉
Personally I like the Prusament filaments but US distribution needs to be beefed up a heck of a lot.  I cannot afford to keep buying them and paying for shipping one spool at a time from Europe.
Amazon Basics (I believe they dropped them) were nice.
Some eSun filaments work well but the colors leave much to be desired.
I mostly use PLA and PETG and I get a lot of them from Amazon because of the convenience.
I have purchased Proto-Pasta, Matter Hackers, eSun, Amazon Basics, and a few others.
The specialty filaments, (ABS, ASA, TPU, Nylon, Metal, Wood, HIPS, and others) are a TOTALLY different world.
Robin
Postato : 21/09/2019 2:30 am
Avoid Glow-in-the-Dark unless you invest in a Tungsten Carbide nozzle ... the particles in it are harder than most hardened steels.
Postato : 21/09/2019 4:11 am
Sembazuru
(@sembazuru)
Posted by: @big-bird
Mop,
When I order filament from Prusa to here in Delaware, I've found that the shipping cost is the same for 2 as it is for 1, but if you order 3 then the shipping cost just about triples. So, I always order filament from Prusa in pairs.
But then, I can always drive over to PrintedSolid (10-15 minute drive) and pick up filament an not have to pay any shipping at all... 😉 I guess I'm just spoiled that way.
See my (limited) designs on:
Postato : 21/09/2019 4:22 am
muo
 muo
(@muo)
Posted by: @bobstro
temp resistance and strength for now
Postato : 21/09/2019 5:05 am
muo
 muo
(@muo)
Posted by: @sembazuru
Mop,
I was able to get my prusamint petg from amazon actually in the US, they have a descent selection of filament may be limited or out of stock but for my needs they had ample options, no need to pay the 50$ shipping fee to US.
https://www.amazon.com/stores/node/19332657011?_encoding=UTF8&field-lbr_brands_browse-bin=Prusament&ref_=bl_dp_s_web_19332657011
Questo post è stato modificato 5 years fa da muo
Postato : 21/09/2019 5:12 am
muo
 muo
(@muo)
Posted by: @tim-m30
i have harden steal nozzle i got https://trianglelab.aliexpress.com/store/group/HOTEND-Nozzle/1654223_512341540.html
i am assuming even though its glow in  the dark PLA it would still make it hard for the harden steal nozzle to work with.
Postato : 21/09/2019 5:27 am
Posted by: @mop
Temp resistance and strength for now
I'm in the "no ABS" camp (fumes are a problem) so PETG is probably a good way to go. Middle of the road temp tolerance puts it between PLA and ABS. Probably good enough for most summer temps, although a hot car in Phoenix might be a challenge. So far as brands, I've used PETG from AtomicFilament, Gizmo Dorks, eSun, Inland and a few other big names. Most print just fine, none were horrible. Price and availability are probably more practical considerations, and that will vary depending on where you are.
I don't have any experience with polycarbonate (yet) but I'm sure some folks can make some recommendations.
Postato : 21/09/2019 6:19 am
Bunny Science
(@bunny-science)
I print primarily PETG and Polycarbonate.
I'll save a bit of typing by repeating what I sent someone. These are from Amazon US....
PETG filaments....
AmazonBasics was my favorite, cheap, reliably well behaved, but is no longer available. Minimal stringing and practically zero warping.
Overture - behaves identically to AmazonBasics.
Paramount - Deep RICH colors that you cannot otherwise obtain. Very well behaved. I would rank this as my top PETG for visual quality.
StrongHero - Great for translucent PETG's and their dark gray is basically gun metal. A bit stringier than the above three if you use out of factory bag. Dry it before printing and you can run E3D & brass nozzle at 260C with minimal stringing. This is a low cost filament, but works well. Just remember it is hugely different wet vs dry.
Strength wise, I get more variation due to nozzle temperature 245 vs 260C than I do filament vs filament. Higher temperature for superior layer fusion requires the filament freshly dried (NOT OUT OF BAG, but heated for drying).
----- PETG's I do NOT recommend
ColorMe3D - Considerably more stringy than above
Priline - Bed adhesion to PEI is excessive. Practically rips PEI off textured plate. All the others listed above easily release when cool, not Priline PETG.
Polycarbonate
Polymaker Polymax is my top choice for polycarbonate. It has higher thermal deflection and strength than Priline. Print at 290C with appropriate speed settings. It can even tolerate a little bit of fan for improved geometry without losing good layer fusion. Prints are so well fused that they sound "glassy" when you strike them with a fingernail.
Priline Polycarbonate is a low cost alternative to Polymax. It isn't as strong or stiff. It's thermal deflection point is about 10-15C lower than Polymax. So although better than PETG for heat resistance, it isn't what I would recommend for hot fins. On the other hand, it is cheaper and prints at 265-270C. Printing at 280 - 290C yields too much stringing even when dried. Like all PC's, its stringiness worsens with moisture Basically, I reach for this when producing parts I need stiffer than PETG, but don't need the temperature resistance of Polymax.
Priline Polycarbonate Carbon Fiber - Produces beautiful matte surface finish using same settings as its non-carbon fiber Priline sibline. It works perfectly with Tungsten carbide nozzle. Delamination is a risk unless you print at the upper end of the Priline PC temp range (270C).
Polycarbonates I do NOT recommend
Gizmo Dorks - I could NEVER get it to adhere to a print bed be it PEI or Phenolic with or without PVA glue.
This no name chinese PC https://www.amazon.com/gp/product/B075SXS6NP Stay away from this! It fractionated into different plastic components. Its lower melt, clear stuff penetrates and ruins phenolic surfaces.
Advice re PC.
Polycarbonates are not cheap. Going cheap means worse print results, no print results, or damaged print bed. All the polycarbonates need thorough drying immediately before use. They are exquisitely sensitive to moisture. Factory sealed bags are NOT dry enough. The high print temp + hygroscopic character --> lots of pops in extrusion, failed bridges,  and horrible stringing. Dry them or waste some pricey filament.
A phenolic print bed is great for polycarbonate. You can use commercial Garolyte or DIY phenolic. I strongly advise using PVA glue and brim on every polycarbonate print. Otherwise, 1st layer adhesion is just enough to appear OK for first few layers, but fails a couple hours later. You don't want a polycarbonate blob of death.
Questo post è stato modificato 5 years fa da Bunny Science
Postato : 21/09/2019 8:22 am
Novaspiro, Boulder, Painted Futures e 2 persone hanno apprezzato
muo
 muo
(@muo)
Posted by: @guy-k2
Interesting i have StrongHero3d PETG, i had initially though i needed to dry it but had no way to do so until i make a dryer, so in order to make this filament work i had to set my extrude rate to like .9  due to stringing and oozing, and i was told that my extrude rate was to drastic, so i put the filament away for a while, but this confirms my suspicions now. i was even about to just call it a bad batch and low quality filament but now this changes things, thanks for the info!
Postato : 21/09/2019 9:31 am
ron
 ron
(@ron)
I like the Amphora AM1800. Not an abs, not really a petg (no stringing but more warping sensible). good interlayer adhesion. I heard luzbot sell some in the US but not checked.
Postato : 21/09/2019 12:48 pm
Bunny Science
(@bunny-science)
Oh no! Newly arrived 5 rolls of Stronghero dark gray is not gun metal. It's a smokey translucent instead of the color I loved.
Postato : 21/09/2019 8:47 pm
Alpha
(@alpha)
I have to say, it's maybe testament to Prusa that the quality distance between high quality and low quality pla filament is pretty narrow.
 On the cheap end I've bulk bought Sunlu, Amazonbasics and more recently Geeetech and all perform very well. Geeetech is slightly more stringy, but nothing that interferes with prints.
High end I've tried Prusament and various others, but to be honest there's nothing I can perceive that justifies the higher price.
For specialist or exotic filaments, this is where I'd remain in better quality bracket.
Postato : 22/09/2019 7:01 am
Bunny Science
(@bunny-science)
I stand corrected, got the shipments mixed up. All five new rolls of Stronghero gray are their super lovely gun metal gray.
It was one "black" spool of another shipping box that is oddly not black, but translucent smoked. Weird.
Well. At least I have more of my favorite gun metal gray filament again. 😀
Postato : 22/09/2019 10:02 am
I've been rather impressed with this stuff: PLA2 from FilaCube.
https://www.amazon.com/gp/product/B07F21M533
Really happy with: Tianse Wood Types
https://www.amazon.com/gp/product/B06Y5M352Z
Happy enough with: Dikale
https://www.amazon.com/gp/product/B079BYK2DT
And used bunches of Paramount Pantone Colored PLA; 3D Solutech PLA (was cheap); and Amolen PLA.
I used a spool of this for printer add-ons - was close enough to Prusa Orange:
https://www.amazon.com/gp/product/B07D6HTSFZ   (no stock)
If I were buying filament soon, I'd be trying out this brand ($15 a kg, delivered):
https://www.amazon.com/dp/B07VB7HFHW
Postato : 22/09/2019 10:26 am
Utenti
I love atomic filament PLA and PETG.
Postato : 22/09/2019 3:53 pm
muo
 muo
(@muo)
Posted by: @tim-m30
nice i think i wana try some of those, just wondering though even if the results are good with the filaments what about long term results for example, what is your experience long term with this filament will they clog, will they ware out nozzle faster vs the normal ware and tare with filament of same material if the manufacturer put hard particles in it, etc.........?
Postato : 23/09/2019 5:24 am
rmm200
(@rmm200)
Joan - someone - can you please correct the title of this thread. Bugs me every time I see it..
But not enough to want to appear a grammar geek. This is to mods only - rest of you ignore it.
Postato : 23/09/2019 5:21 pm
Pagina 1 / 2
