					                		ASA Stuck To Plate??? - General discussion, announcements and releases                                    </title>
                <link>https://forum.prusa3d.com/forum/english-forum-general-discussion-announcements-and-releases/asa-stuck-to-plate/</link>
                <lastBuildDate>Sat, 16 May 2026 18:12:45 +0000</lastBuildDate>
                        <title>RE: ASA Stuck To Plate???</title>
                        <link>https://forum.prusa3d.com/forum/english-forum-general-discussion-announcements-and-releases/asa-stuck-to-plate/#post-791516</link>
                        <pubDate>Wed, 06 May 2026 12:33:35 +0000</pubDate>
                        <description><![CDATA[Posted by: @michael-kuran If that happens again I will try the freezer thing! I’ve seen lots of people use those torches in videos but wasn’t really sure why? I’ve got plenty of prototypes l...]]></description>
                        <content:encoded><![CDATA[<blockquote data-userid="607888" data-postid="791494" data-mention="michael-kuran"><div class="wpforo-post-quote-author"><strong>Posted by: @michael-kuran </strong></div><p>If that happens again I will try the freezer thing! I’ve seen lots of people use those torches in videos but wasn’t really sure why? I’ve got plenty of prototypes laying around I might that a go. Would you explain why you would use one? Any dos or don’ts? Thanks for taking the time to help out!</p><p>Mike</p></blockquote><p>As it happens what I bought the butane burner for was a complete failure. I had heaps of butane left over from camp stoves we no longer use, and I bought some silicone molds to re-purpose waste filament into colourful other things like guitar picks. It seemed like a good idea at the time. I thought the burner would melt the material faster and more effectively than the heat gun I was using - it didn't really, and led to several small smelly fires. </p><p>What I've moved onto using it for now is cleaning up stray strings, hairs, blobs and blemishes, especially on PETG. They vanish with a quick pass with the butane flame at distance. Too close and you risk melting the object (or worse). When it works it's great to see, and saves a heap of time.</p><p>And tbh Mike it does involve fire and a cool rocket-like roar, so there's always that 🤣 </p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/english-forum-general-discussion-announcements-and-releases/">General discussion, announcements and releases</category>                        <dc:creator>Geoff Steele</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/english-forum-general-discussion-announcements-and-releases/asa-stuck-to-plate/#post-791516</guid>
                        <link>https://forum.prusa3d.com/forum/english-forum-general-discussion-announcements-and-releases/asa-stuck-to-plate/#post-791507</link>
                        <pubDate>Wed, 06 May 2026 11:05:05 +0000</pubDate>
                        <description><![CDATA[Over time, all plates accumulate microscopic surface damage and &quot;roughen up&quot;.  I have had PETG glued to the textured plate and had to use a metal razor to remove it.  I often use window clea...]]></description>
                        <content:encoded><![CDATA[<p>Over time, all plates accumulate microscopic surface damage and "roughen up".  I have had PETG glued to the textured plate and had to use a metal razor to remove it.  I often use window cleaner (Windex) as a release agent with PETG, as the plate increases adherence.  I do not use a lot of ASA, but I could see this as an issue with it also.  Glue stick makes sense with it.  </p><blockquote data-userid="607888" data-postid="791465" data-mention="michael-kuran"><div class="wpforo-post-quote-author"><strong> Posted by: @michael-kuran </strong></div><p>The part actually pealed of the coating on the smooth plate! I’ve print lots of these and never stuck that bad! </p><div id="wpfa-186233" class="wpforo-attached-file"><a class="wpforo-default-attachment" title="9f0f7f69-9274376e-04b7-48dd-9f51-ffe75dfe8f7c.jpeg" href="//storage.googleapis.com/prusa3d-content-prod-14e8-wordpress-forum-prod/wpforo/default_attachments/1778020931-9f0f7f69-9274376e-04b7-48dd-9f51-ffe75dfe8f7c.jpeg" target="_blank" rel="noopener"> 9f0f7f69-9274376e-04b7-48dd-9f51-ffe75dfe8f7c.jpeg</a></div></blockquote><p> </p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/english-forum-general-discussion-announcements-and-releases/">General discussion, announcements and releases</category>                        <dc:creator>cwbullet</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/english-forum-general-discussion-announcements-and-releases/asa-stuck-to-plate/#post-791507</guid>
                        <link>https://forum.prusa3d.com/forum/english-forum-general-discussion-announcements-and-releases/asa-stuck-to-plate/#post-791501</link>
                        <pubDate>Wed, 06 May 2026 09:46:09 +0000</pubDate>
                        <description><![CDATA[Use glue sticks on your plates before you print with these materials. you need very little glue and don&#039;t need to glue very often.]]></description>
                        <content:encoded><![CDATA[<p>Use glue sticks on your plates before you print with these materials. you need very little glue and don't need to glue very often.</p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/english-forum-general-discussion-announcements-and-releases/">General discussion, announcements and releases</category>                        <dc:creator>faslger</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/english-forum-general-discussion-announcements-and-releases/asa-stuck-to-plate/#post-791501</guid>
                        <link>https://forum.prusa3d.com/forum/english-forum-general-discussion-announcements-and-releases/asa-stuck-to-plate/#post-791497</link>
                        <pubDate>Wed, 06 May 2026 09:38:06 +0000</pubDate>
                        <description><![CDATA[Early on I had warping problems using the textured plate and it seemed to clear up with the smooth plate. So I have been using it. But I did try printing the other half of that project on a ...]]></description>
                        <content:encoded><![CDATA[<p>Early on I had warping problems using the textured plate and it seemed to clear up with the smooth plate. So I have been using it. But I did try printing the other half of that project on a textured plate. It finished over night and this morning they slid right off. With no warping! Originally I think my bed and chamber temps were too low. I have a heat gun and a torch one better than the other?</p><p>Mike</p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/english-forum-general-discussion-announcements-and-releases/">General discussion, announcements and releases</category>                        <dc:creator>Michael Kuran</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/english-forum-general-discussion-announcements-and-releases/asa-stuck-to-plate/#post-791497</guid>
                        <link>https://forum.prusa3d.com/forum/english-forum-general-discussion-announcements-and-releases/asa-stuck-to-plate/#post-791494</link>
                        <pubDate>Wed, 06 May 2026 09:32:17 +0000</pubDate>
                        <description><![CDATA[If that happens again I will try the freezer thing! I’ve seen lots of people use those torches in videos but wasn’t really sure why? I’ve got plenty of prototypes laying around I might that ...]]></description>
                        <content:encoded><![CDATA[<p>If that happens again I will try the freezer thing! I’ve seen lots of people use those torches in videos but wasn’t really sure why? I’ve got plenty of prototypes laying around I might that a go. Would you explain why you would use one? Any dos or don’ts? Thanks for taking the time to help out!</p><p>Mike</p>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/english-forum-general-discussion-announcements-and-releases/asa-stuck-to-plate/#post-791494</guid>
                        <link>https://forum.prusa3d.com/forum/english-forum-general-discussion-announcements-and-releases/asa-stuck-to-plate/#post-791493</link>
                        <pubDate>Wed, 06 May 2026 09:31:51 +0000</pubDate>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/english-forum-general-discussion-announcements-and-releases/asa-stuck-to-plate/#post-791493</guid>
                        <link>https://forum.prusa3d.com/forum/english-forum-general-discussion-announcements-and-releases/asa-stuck-to-plate/#post-791484</link>
                        <pubDate>Wed, 06 May 2026 07:19:27 +0000</pubDate>
                        <description><![CDATA[I don&#039;t know if this would have prevented this damage, but I also destroyed my first smooth plate with some stubborn PETG. Recently I had a stuck print and a mate gave me the tip of putting ...]]></description>
                        <content:encoded><![CDATA[<p>I don't know if this would have prevented this damage, but I also destroyed my first smooth plate with some stubborn PETG. Recently I had a stuck print and a mate gave me the tip of putting it in the freezer which not only released the print overnight, but also the plate was unmarked.</p>
<p>I have a butane torch for cleaning up the models. I've made a mess of that once or twice too...always learning with this process 🤣 </p>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/english-forum-general-discussion-announcements-and-releases/asa-stuck-to-plate/#post-791484</guid>
                        <link>https://forum.prusa3d.com/forum/english-forum-general-discussion-announcements-and-releases/asa-stuck-to-plate/#post-791482</link>
                        <pubDate>Wed, 06 May 2026 07:02:33 +0000</pubDate>
                        <description><![CDATA[Posted by: @michael-kuran How can I clean up the end of this part that was stuck to the plate? a9e2175d-9cc25260-8d84-4bb8-947f-2fa3d353ceb8.JPEGYou can use a hair dryer, a heat gun, a small...]]></description>
                        <content:encoded><![CDATA[<p> </p><blockquote data-userid="607888" data-postid="791466" data-mention="michael-kuran"><div class="wpforo-post-quote-author"><strong> Posted by: @michael-kuran </strong></div><p>How can I clean up the end of this part that was stuck to the plate?</p><div id="wpfa-186235" class="wpforo-attached-file"><a class="wpforo-default-attachment" title="a9e2175d-9cc25260-8d84-4bb8-947f-2fa3d353ceb8.JPEG" href="//storage.googleapis.com/prusa3d-content-prod-14e8-wordpress-forum-prod/wpforo/default_attachments/1778021532-a9e2175d-9cc25260-8d84-4bb8-947f-2fa3d353ceb8.jpeg" target="_blank" rel="noopener"> a9e2175d-9cc25260-8d84-4bb8-947f-2fa3d353ceb8.JPEG</a></div></blockquote><p>You can use a hair dryer, a heat gun, a small torch, or a lighter to carefully treat the surface.</p><p>In the future, you might want to use textured or satin-finished printing plates. That way, you won’t end up damaging your printing plate.</p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/english-forum-general-discussion-announcements-and-releases/">General discussion, announcements and releases</category>                        <dc:creator>jan.d.slay</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/english-forum-general-discussion-announcements-and-releases/asa-stuck-to-plate/#post-791482</guid>
                        <link>https://forum.prusa3d.com/forum/english-forum-general-discussion-announcements-and-releases/asa-stuck-to-plate/#post-791466</link>
                        <pubDate>Tue, 05 May 2026 22:52:11 +0000</pubDate>
                        <description><![CDATA[How can I clean up the end of this part that was stuck to the plate?
&nbsp;a9e2175d-9cc25260-8d84-4bb8-947f-2fa3d353ceb8.JPEG]]></description>
                        <content:encoded><![CDATA[<p>How can I clean up the end of this part that was stuck to the plate?</p>
<div id="wpfa-186235" class="wpforo-attached-file"><a class="wpforo-default-attachment" href="//storage.googleapis.com/prusa3d-content-prod-14e8-wordpress-forum-prod/wpforo/default_attachments/1778021532-a9e2175d-9cc25260-8d84-4bb8-947f-2fa3d353ceb8.jpeg" target="_blank" title="a9e2175d-9cc25260-8d84-4bb8-947f-2fa3d353ceb8.JPEG"><i class="fas fa-paperclip"></i>&nbsp;a9e2175d-9cc25260-8d84-4bb8-947f-2fa3d353ceb8.JPEG</a></div>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/english-forum-general-discussion-announcements-and-releases/asa-stuck-to-plate/#post-791466</guid>
                        <title>ASA Stuck To Plate???</title>
                        <link>https://forum.prusa3d.com/forum/english-forum-general-discussion-announcements-and-releases/asa-stuck-to-plate/#post-791465</link>
                        <pubDate>Tue, 05 May 2026 22:42:11 +0000</pubDate>
                        <description><![CDATA[The part actually pealed of the coating on the smooth plate! I’ve print lots of these and never stuck that bad! 
&nbsp;9f0f7f69-9274376e-04b7-48dd-9f51-ffe75dfe8f7c.jpeg]]></description>
                        <content:encoded><![CDATA[<p>The part actually pealed of the coating on the smooth plate! I’ve print lots of these and never stuck that bad! </p>
<div id="wpfa-186233" class="wpforo-attached-file"><a class="wpforo-default-attachment" href="//storage.googleapis.com/prusa3d-content-prod-14e8-wordpress-forum-prod/wpforo/default_attachments/1778020931-9f0f7f69-9274376e-04b7-48dd-9f51-ffe75dfe8f7c.jpeg" target="_blank" title="9f0f7f69-9274376e-04b7-48dd-9f51-ffe75dfe8f7c.jpeg"><i class="fas fa-paperclip"></i>&nbsp;9f0f7f69-9274376e-04b7-48dd-9f51-ffe75dfe8f7c.jpeg</a></div>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/english-forum-general-discussion-announcements-and-releases/asa-stuck-to-plate/#post-791465</guid>
