ASA Stuck To Plate???
Michael Kuran
(@michael-kuran)
The part actually pealed of the coating on the smooth plate! I’ve print lots of these and never stuck that bad!
Posted : 05/05/2026 10:42 pm
Michael Kuran
(@michael-kuran)
RE: ASA Stuck To Plate???
How can I clean up the end of this part that was stuck to the plate?
Posted : 05/05/2026 10:52 pm
jan.d.slay
(@jan-d-slay)
Posted by: @michael-kuran
You can use a hair dryer, a heat gun, a small torch, or a lighter to carefully treat the surface.
In the future, you might want to use textured or satin-finished printing plates. That way, you won’t end up damaging your printing plate.
Posted : 06/05/2026 7:02 am
Geoff Steele
(@geoff-steele)
I don't know if this would have prevented this damage, but I also destroyed my first smooth plate with some stubborn PETG. Recently I had a stuck print and a mate gave me the tip of putting it in the freezer which not only released the print overnight, but also the plate was unmarked.
I have a butane torch for cleaning up the models. I've made a mess of that once or twice too...always learning with this process 🤣
This post was modified 2 days ago by Geoff Steele
Posted : 06/05/2026 7:19 am
Michael Kuran
(@michael-kuran)
If that happens again I will try the freezer thing! I’ve seen lots of people use those torches in videos but wasn’t really sure why? I’ve got plenty of prototypes laying around I might that a go. Would you explain why you would use one? Any dos or don’ts? Thanks for taking the time to help out!
Mike
Posted : 06/05/2026 9:31 am
Michael Kuran
(@michael-kuran)
Mike
Posted : 06/05/2026 9:32 am
Michael Kuran
(@michael-kuran)
Early on I had warping problems using the textured plate and it seemed to clear up with the smooth plate. So I have been using it. But I did try printing the other half of that project on a textured plate. It finished over night and this morning they slid right off. With no warping! Originally I think my bed and chamber temps were too low. I have a heat gun and a torch one better than the other?
Mike
Posted : 06/05/2026 9:38 am
faslger
(@faslger)
Use glue sticks on your plates before you print with these materials. you need very little glue and don't need to glue very often.
Posted : 06/05/2026 9:46 am
Over time, all plates accumulate microscopic surface damage and "roughen up".  I have had PETG glued to the textured plate and had to use a metal razor to remove it.  I often use window cleaner (Windex) as a release agent with PETG, as the plate increases adherence.  I do not use a lot of ASA, but I could see this as an issue with it also.  Glue stick makes sense with it.
Posted : 06/05/2026 11:05 am
Geoff Steele
(@geoff-steele)
Mike
As it happens what I bought the butane burner for was a complete failure. I had heaps of butane left over from camp stoves we no longer use, and I bought some silicone molds to re-purpose waste filament into colourful other things like guitar picks. It seemed like a good idea at the time. I thought the burner would melt the material faster and more effectively than the heat gun I was using - it didn't really, and led to several small smelly fires.
What I've moved onto using it for now is cleaning up stray strings, hairs, blobs and blemishes, especially on PETG. They vanish with a quick pass with the butane flame at distance. Too close and you risk melting the object (or worse). When it works it's great to see, and saves a heap of time.
And tbh Mike it does involve fire and a cool rocket-like roar, so there's always that 🤣
Posted : 06/05/2026 12:33 pm
