Advice for drafting/printing an odd, asymmetric plate for a repair?
Evan Judson
(@evan-judson)
Hi all, i'm trying to print a replacement back for a vintage porcelain clock. The original is a badly warped piece of mason board or something and i'm trying to get a workable trace of it in fusion360. I took a second jab at it last night, taking a pic of it on my mk3s print plate so i can use the grid to calibrate it as a canvas in f360 and it once again came out stretched in a weird direction. I really wish it could be as easy as just getting one side right then mirroring it but unfortunately its not symmetrical to begin with. Last time it was too wide, this time its too tall and somehow narrow at the bottom.
Any tips before i burn a  whole spool on test fits?
Postato : 17/09/2025 3:02 pm
Steve
(@steve-5)
RE: Advice for drafting/printing an odd, asymmetric plate for a repair?
This is a tricky problem to get right as there is hidden parallax error in the photographic method.  A few things that have helped me when doing this:
1.  Lay a scale (metal ruler, preferably a machinist's scale or the like for better precision and as long as you can fit (the longer the scale the less conversion error)) on the surface of the object.  This is a far better reference to scale the canvas in Fusion and since you will be tracing the top surface of the object you need the scale in the same plane as that surface.  Orient it as precisely as you can along one of the axes of the part for a convenient rotational reference in Fusion as well.
2.  Get the camera as far away from the surface of the object as practical, use the zoom function of the camera to "fill" the viewfinder.  This is important as the closer the lens is to the object the greater the parallax error  due to the object having physical height above the surface.
3.  Try to get the lighting as uniform as possible and as directly above the object as practical to avoid shadows around the edges which will make tracing the canvas more difficult.
I hope this is of some help, good luck.
Regards,
Steve
Postato : 17/09/2025 4:42 pm
John Lindo
(@john-lindo)
Evan, I work on old clocks and masonite board IMHO is not really vintage.
Anyway, your photo shows the circumference or shape symmetrical enough for the back of a clock, which will not be seen normally.
The only non symmetry is the 3 hanging ? holes.
You can always print this part  in 2 pieces, and tape together if your print bed is not large enough.
Evan Judson
(@evan-judson)
thanks, i figured it had to be some kind of angled photo. It looks straight on, and my pixel has a gyro kind of thingy when the camera's up that tells you when you're aiming straight-on at the subject, but its definitely not perfect. I'll give these a try tonight
Postato : 17/09/2025 5:07 pm
Evan Judson
(@evan-judson)
its tricky and it took me some time to notice it myself thinking it was symmetrical but if i stand up the back cover so its resting on the 2 lowest points, the peak of it will be centered but the two left and right-most points are at different heights. Its a strange shape - old clock from the 50s, kind of cartoonish. All else fails maybe i can do the 2 halves thing and just drill the holes where they needs be i suppose.
Postato : 17/09/2025 5:10 pm
J and Jil
(@j-and-jil)
I've done a lot of 2D drafting over the years and when I want to take an image of an object for vector tracing what I do is:
1. set it on a gridded background like a cutting with lines spaced at known dimensions.
2. get a step stool or even a ladder to stand on and get high above the object and then zoom in to the object, this takes out some of the perspective vanishing point effect and gives a more orthagonal image.
3. bring the image in Photoshop, turn on the Grid for reference and square the image up using the distort and other editing commands, by making the lines on the cutting mat match the Grid.
4. finally import the image in and then scale it using the lines on the cutting mat.
Good luck!
Postato : 19/09/2025 3:43 pm
JP Guitars
(@jp-guitars)
To add to the above...
3.5 Print it out full size. Carefully cut it out and check for fit.
That way you are wasting paper and ink not filament
Postato : 19/09/2025 4:09 pm
1 persone hanno apprezzato
Chris Hill
(@chris-hill)
A flatbed scanner is a good way of getting an accurate image.  Even if you have to do it in two halves you can be reasonably confident that the two scans will match up.
Postato : 19/09/2025 4:42 pm
Tim
 Tim
(@tim-24)
Utenti
Place the clock back side down on a scanner. This gives you an image of the back and usually a few millimeters up into the cavity that is the actual the size you need to fit. Typically flat bed scanners are very accurate, but you might have to adjust scale when printing to ensure the printer and scanner are a true 1 to 1.  This gives a basis to ensure whatever you do with the back plate will fit the space available.
Postato : 19/09/2025 5:04 pm
Tim
 Tim
(@tim-24)
Utenti
As an aside to making a new back, you could always try flattening the existing back. Clamp it between two plates of safety glass or a couple of stout cookie sheets and heat it in an oven at 170F for several hours. Essentially retrain the wood fibers to their old shape.
I've also taken the liberty to convert the image into an STL, but you'll need to rescale to match your part.
Postato : 19/09/2025 5:39 pm
srmalloy
(@srmalloy)
Utenti
Another trick that I've used to get a useful scale on objects like this is to photocopy it onto a sheet of graph paper; that will give you a finer grid for taking measurements, and you can make the sheet of graph paper as flat as you need. If it's too warped to lay or press flat in the copier, I've had some success with lightly steaming it to soften it a bit, putting it into a folded towel on a table with a stack of books on top, and letting the weight unwarp it.
Postato : 21/09/2025 3:48 am
