Adhesive for TPU to PETG
Robin_13
(@robin_13)
I am working on a project that requires some TPU parts and I need to glue them to PETG parts.  I have tried  both superglue and polyurethane so far with little success.  In both cases, the TPU separated from the PETG.  Adhesive stuck to the PETG, not the TPU.  I do need a decent bond.
Searches on the web have not lead to any success.
Opublikowany : 05/09/2025 6:18 pm
Walter Layher
(@walter-layher)
RE: Adhesive for TPU to PETG
I have successfully printed PETG on TPU with a simple color change in PrusaSlicer and increasing the nozzle (not the bed!) temperature up to PETG level. No adhesives at all. Both parts have a solid bond. I used SainSmart TPU 95/A Black and Amazon Basic Clear PETG (because that was just loaded in the dryer for another print).
It was this model: https://www.printables.com/model/914645-sennheiser-rs-185-hdr-185-headband
I posted a make there that I still use today, more than a year later, and print still looks like in the photo there.
Opublikowany : 05/09/2025 7:33 pm
1 ludzie polubili
Thomas Lynch
(@thomas-lynch)
I use GOOP. If the parts cannot be printed on top of one another. I use it to bond TPU tires on cars that I build to the wheels, both are printed separately. Works every time.
Tom
Opublikowany : 06/09/2025 3:02 pm
Hot melt glues stick both well but practice on some scraps first as it's easy to overheat and melt through the part....
Opublikowany : 06/09/2025 3:56 pm
Robin_13
(@robin_13)
I will have to test printing the TPU onto the PETG.  Due to the part, I cannot print directly but I can make a sub part and glue it into the main part.  Worth testing.  Thanks for the suggestion.
Opublikowany : 07/09/2025 6:43 pm
Robin_13
(@robin_13)
I just did a test with GLOOZIT Industrial sealant & adhesive.  It holds pretty well as I have not been able to separate the parts yet.  The stuff makes me think of GOOP which I have used on different things.  I don't have any GOOP at this time to test.  Overall, I find that GOOP is a good general purpose adhesive.
Which type of GOOP did you use?
Opublikowany : 07/09/2025 6:46 pm
Robin_13
(@robin_13)
There are many comments about using heat to prep the surface for using adhesives.  Hot melt glue may be a good option to test.  My not give me the precision I need.  Thanks for the suggestion.
Opublikowany : 07/09/2025 6:48 pm
