hollow draudi
Page 2 / 2
MPJ
 MPJ
(@mpj)
Re: hollow draudi
I think bottom side turned out very good, don't see that same roughness you guys experienced.
Posted : 30/06/2017 4:17 pm
Knickohr
(@knickohr)
Member Moderator
Re: hollow draudi
Tell us more about your print settings ! Parameters, Cooling, ...
Thomas
Posted : 30/06/2017 7:01 pm
MPJ
 MPJ
(@mpj)
Re: hollow draudi
I used the provided gcode and all I did was turn the temperature to 190 after first layer since it was stringing, so thought that might help it. Other than that, I don't know what settings were used in the provided gcode, guess it was the filament because should of turned out the same as JeffJordans print.
Maybe I got lucky.
Posted : 30/06/2017 10:25 pm
JeffJordan
(@jeffjordan)
Member Moderator
Re: hollow draudi
very good... so my genuine settings were nearly pristine, except the filament temperature.
I usually use some more degrees to increase the bonding between the layers.
anyhow, thanks for that print and posting it. it'll help to improve further prints 🙄 -
Posted : 01/07/2017 9:45 am
Knickohr
(@knickohr)
Member Moderator
Re: hollow draudi
My draudi :mrgreen:
The belly looks good 😎
But there are other problematic areas
Who says printing ABS with an fan is terrible ? Printed with rigid.ink ABS 230/90° 50% fan start at layer 5, bridges 100% fan, took nearly 14 hours to print. I rescaled the draudi to 125% to fit on full print plate. Use 10mm brim for better adhere on the plate !
Thomas
Posted : 16/07/2017 12:19 am
JeffJordan
(@jeffjordan)
Member Moderator
Re: hollow draudi
pretty good for abs ❗
and yes, I'm using the print fan as well (with approx. 30%).
Posted : 16/07/2017 1:40 am
Knickohr
(@knickohr)
Member Moderator
Re: hollow draudi
This happens if you smooth the Draudi with acetone 😯 😥
But the girl looks fine 😎
Thomas
Posted : 27/07/2017 5:40 pm
LaPointe
(@lapointe)
French moderator and translator Moderator
Re: hollow draudi
A flat Draudi :mrgreen:
Posted : 28/07/2017 8:04 am
Knickohr
(@knickohr)
Member Moderator
Re: hollow draudi
R.I.P.
Thomas
Posted : 28/07/2017 9:31 am
JeffJordan
(@jeffjordan)
Member Moderator
Re: hollow draudi
yeah, but the girl isn't flat at all and very tempting :mrgreen: .
Posted : 28/07/2017 11:53 am
Tom
 Tom
(@tom)
Re: hollow draudi
Have you tried to do a cold vapor smooth with acetone? I don't think that will happen then as long as you let the print rest a few hours after before touching.
Posted : 28/07/2017 12:53 pm
Page 2 / 2
