Hairy Lion
Page 2 / 2
richard.l
(@richard-l)
Member Moderator
Re: Hairy Lion
Just for you... (and Thomas, if he wishes to try it)
Please note that this is sliced with KISS 1.6 Alpha 7.1 which contains some very "experimental" features for the Mk2 Quad upgrade.
I have commented out some of the start GCode (with a ";PJR') and you should add your own PID etc. Otherwise, I think the start GCode should be fine.
Sliced at 0.2mm layers for E1 (T0) single extrusion. As for the "experimental" features; I have found them to work very well and as you have seen, I have printed this model sliced with the same version of KISS.
Peter
Start GCode looks fine but there are some things further down that may be problematic without the MM upgrade. There are some "Destring Suck"/"Destring Prime" lines that I am not familiar with. They resemble retraction but at 3.5mm that is quite extreme.
Thanks anyway. Maybe after a couple years I should really take a weekend to try and sort KISS out.
Posted : 02/04/2017 11:14 pm
PJR
 PJR
(@pjr)
Antient Member Moderator
Re: Hairy Lion
Richard
Ah, sorry, I forgot about that. Yes, the MM upgrade does use up to 6mm in prime/suck for retractions. I will reslice later today.
Peter
Posted : 03/04/2017 7:40 am
Page 2 / 2
