Dyeing filaments - PETG, PVB, Nylon, PLA ?
Not a print (yet), more of a question - does anyone here have experience dyeing filament to get a desired color / effect ? I have seen this post ( https://richrap.blogspot.com/2013/04/3d-printing-with-nylon-618-filament-in.html) on dyeing Nylon from 2013: wondering if anyone here has had experience more recently and / or with other materials. Ideally, I could dye my PVB to get a stained - glass like finish with different colors from stock.
Prusa is MK4 w/ MMU3 (formerly MK3S+/MMU2), 2 Prusa MINI+, Octoprint
There is another way:
You can get quite a strong 'stained glass' effect by starting with clear filament.
RE: Dyeing filaments - PETG, PVB, Nylon, PLA ?
@diem - thanks for this - I was considering how to apply the dye as the filament rolls off the spool. The marker hack produces a nice result (just need to make an adapter for MK4/MMU3).
That said, I am still looking at ways to increase the pigment infusion into the filament if I can to get bolder color: using a hygroscopic filament like PVB, I can get the dye to soak through almost to the core, and get some very strong, true color.
So far, with PETG, I am only getting the dye around the outer ring of the filament (like the marker method, but a bit deeper), which results in a nice, stable looking color with translucent PETG, but with a solid PETG (like white), you can see that the blend is inconsistent, resulting in a lighter color and striping.
Posting a pic of my first dye job for reference here if someone else wants to try this. The dye was red iDyePoly for synthetics ( https://www.jacquardproducts.com/idye-main). The top was a translucent PVB filament, the next a translucent PETG, the next a white PETG (note striping due to inconsistent blend, shallow dye penetration).
Ultimately, I'd like to get to the point where I can blend not just a nice color, but rather a specific color that can get me a consistent match to a hex color code. Mellonta tauta!
Update on this - if you want to try it at home with PETG, you must use the synthetic dyes. The RIT all purpose dyes (like these: https://www.ritdye.com/type/all-purpose-dye/) won't dent the PETG, even when it is heated to the point of deformation.
