					                		Quick Way to Punch Holes in 100 Transparancies - Coronavirus (COVID-19)                                    </title>
                <link>https://forum.prusa3d.com/forum/coronavirus-covid-19/quick-way-to-punch-holes-in-100-transparancies/</link>
                <lastBuildDate>Tue, 12 May 2026 00:28:23 +0000</lastBuildDate>
                        <title>RE: Quick Way to Punch Holes in 100 Transparancies</title>
                        <link>https://forum.prusa3d.com/forum/coronavirus-covid-19/quick-way-to-punch-holes-in-100-transparancies/#post-204602</link>
                        <pubDate>Fri, 03 Apr 2020 09:03:06 +0000</pubDate>
                        <description><![CDATA[In case you don’t see the drill press in the first photo, I don’t recommend drilling with a hand held drill.]]></description>
                        <content:encoded><![CDATA[<p>In case you don’t see the drill press in the first photo, I don’t recommend drilling with a hand held drill. </p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/coronavirus-covid-19/">Coronavirus (COVID-19)</category>                        <dc:creator>John</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/coronavirus-covid-19/quick-way-to-punch-holes-in-100-transparancies/#post-204602</guid>
                        <link>https://forum.prusa3d.com/forum/coronavirus-covid-19/quick-way-to-punch-holes-in-100-transparancies/#post-204565</link>
                        <pubDate>Fri, 03 Apr 2020 02:17:28 +0000</pubDate>
                        <description><![CDATA[Posted by: @mitch-w What spacing did you use? I tried the 888 (2 inner holes centered on page and 8cm apart, two outer holes 8cm from inner) but it does not fit.  Not sure if I am using wron...]]></description>
                        <content:encoded><![CDATA[<blockquote data-userid="2236" data-postid="204470" data-mention="mitch-w"><div class="wpforo-post-quote-author"><strong> Posted by: @mitch-w </strong></div><p>What spacing did you use? I tried the 888 (2 inner holes centered on page and 8cm apart, two outer holes 8cm from inner) but it does not fit.  Not sure if I am using wrong pattern, or if my print scale is off?</p></blockquote><p>I made one by hand.  I took one sheet and held it up to the shield frame and marked where the holes should go and then I transfer that to my stack.  Just make sure you go off the base of the peg.</p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/coronavirus-covid-19/">Coronavirus (COVID-19)</category>                        <dc:creator>jurassic73</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/coronavirus-covid-19/quick-way-to-punch-holes-in-100-transparancies/#post-204565</guid>
                        <link>https://forum.prusa3d.com/forum/coronavirus-covid-19/quick-way-to-punch-holes-in-100-transparancies/#post-204470</link>
                        <pubDate>Thu, 02 Apr 2020 19:04:28 +0000</pubDate>
                        <description><![CDATA[What spacing did you use? I tried the 888 (2 inner holes centered on page and 8cm apart, two outer holes 8cm from inner) but it does not fit.  Not sure if I am using wrong pattern, or if my ...]]></description>
                        <content:encoded><![CDATA[<p>What spacing did you use? I tried the 888 (2 inner holes centered on page and 8cm apart, two outer holes 8cm from inner) but it does not fit.  Not sure if I am using wrong pattern, or if my print scale is off?</p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/coronavirus-covid-19/">Coronavirus (COVID-19)</category>                        <dc:creator>mitch.w</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/coronavirus-covid-19/quick-way-to-punch-holes-in-100-transparancies/#post-204470</guid>
                        <title>Quick Way to Punch Holes in 100 Transparancies</title>
                        <link>https://forum.prusa3d.com/forum/coronavirus-covid-19/quick-way-to-punch-holes-in-100-transparancies/#post-204029</link>
                        <pubDate>Wed, 01 Apr 2020 02:42:31 +0000</pubDate>
                        <description><![CDATA[Drill them!  Used an 11/64&quot; bit.  Lucked out in that these transparencies shipped shrink wrapped else I was going to have to clamp them together to make the holes.  Drilled four holes to mak...]]></description>
                        <content:encoded><![CDATA[<p>Drill them!  Used an 11/64" bit.  Lucked out in that these transparencies shipped shrink wrapped else I was going to have to clamp them together to make the holes.  Drilled four holes to make 400 holes.  Nice and consistent.</p><p>  <a href="https://forum.prusa3d.com/wp-content/uploads/2020/04/IMG_20200331_192055.jpg"><img class="alignnone size-medium wp-image-22153" src="https://forum.prusa3d.com/wp-content/uploads/2020/04/IMG_20200331_192055-600x500.jpg" alt="" width="600" height="500" /></a> <a href="https://forum.prusa3d.com/wp-content/uploads/2020/04/IMG_20200331_192218.jpg"><img class="alignnone size-medium wp-image-22156" src="https://forum.prusa3d.com/wp-content/uploads/2020/04/IMG_20200331_192218-600x500.jpg" alt="" width="600" height="500" /></a></p><p>Used these: <a href="https://www.amazon.com/gp/product/B07KZKQBZ5/">https://www.amazon.com/gp/product/B07KZKQBZ5/</a></p><p> </p>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/coronavirus-covid-19/quick-way-to-punch-holes-in-100-transparancies/#post-204029</guid>
