Uploads to Prusa Connect not working
I am trying to upload files to my printer via PrusaConnect. For the past two days or so I have been unable to upload files. I select to upload, select the file I want to upload and click "Open" but nothing happens. I have completely closed the browser, deleted all site data for Prusa related sites, and still nothing.
This is Chrome v126 on a Mac M2 Ventura. Anyone else having this issue?
RE: Uploads to Prusa Connect not working
UPDATE: I got it to work but... it's a terrible workaround. If I go to the "Connect Files" link at the top, AND I open my browser dev tools, and from the Network tab make sure "Disable Cache" is selected, THEN it will successfully upload a file.
Still can't upload from the Dashboard screen like I have always done.
Also, I have rebooted my computer since my original post and still seeing the same behavior.
Wipe browser cache/history for Prusa domain.
Yes, I mentioned in my original post that I deleted all site data for Prusa related sites from my browser. This would include cache/history.
This did not resolve the issue.
Same issue, I tried to clear my cache with no luck. I am able to use connect files, transfer to the cloud then transfer to printer as a work around.
@grnarledcardboard, I'm just curious, are you on a Mac as well? Chrome browser?
Yes Mac and Chrome. I just tried Safari and it works fine there. I am using Version 126.0.6478.127 (Official Build) (arm64)
same here on a intel machine worked fine last time I used it, now dashboard transfer of files doesn't work, and returns no errors.
but can ad files trough prusa connect
running windows 10 and chrome browser
logged out, back in. no luck did not try the cash history path though
I had this problem too im using win11 Pro /chrome and nothing i tried would transfer so i changed to firefox and it transfers no dramas so as im not a computer expert i think its a chrome issue . hope this helps
Mark Australia
I have run into this issue as well, my workaround has been to rename the file. There seems to be an issue with having multiple copies of the same file.
Necroing because this issue is still around. Just ran into it.
I made sure only one file of that name existed, reset browser cache, tried printing from the "file connect" tab... even tried downloading the file from there and putting it on the printer's USB drive manually, but even the download button doesn't seem to work so I can't even try that.
