Strange issue where the web interface wont load
Page 1 / 3
Hello
(@hello)
Hi there
Not sure if it's prusalink fault but pretty sure it is
So if I connect a official Raspberry pi pwm fan to the pi and put it inside case I get error on Google carnt find adress like if you google a random ip adress if I disconnect the pwm wire and leave fan powered and spinning all is fine the pi boots fine with pwm fan connect just doesn't allow to connect to local
I don't know if it's prusalink or my pi but since pi boots fine it seems like prusalink how it's related.or affects it is beyond me please help or give advice @tojik
Any logs or tests you need me to do I'd be more then willing I'm on windows so commands for windows if you need anything.
Pi 4 2gb
Printer 2.13
Prusa-Link latest on github from today
No mmu
Publié : 07/08/2023 9:23 am
Tojik
(@tojik)
Membre Moderator
RE: Strange issue where the web interface wont load
Hi, this looks like your pi does not even boot. Try looking at the SD activity LED when you got the PWM signal wire connected. If it does not even blink then there's a real problem somewhere. I would assume a short circuit getting created. Is it a PWM signal wire? Could you have confused a tacho wire for a PWM signal one? Anyway, you can try with a clean Pi OS SD and see if that boots. Also, you can connect the peripherals and verify it booting that way.
Publié : 07/08/2023 12:00 pm
Hello
(@hello)
If I connect to my friends monitor it boots fine it's the official pi4 case fan so it's definitely pwm it is really strange
Publié : 07/08/2023 7:19 pm
Hello
(@hello)
@tojik I wonder if it's interfering with wifi connection is it possible anyway to check via ssh if I plug pwm then unplug and ssh
Publié : 07/08/2023 7:26 pm
Tojik
(@tojik)
Membre Moderator
I wonder the same thing. You can definitely enable the ssh by adding an empty file named "ssh" with no file extension into the sd boot partition.
Also, you can see the /var/log/syslog file and watch for a line saying "carrier lost" appearing after you connect the pwm line
Publié : 07/08/2023 7:29 pm
Hello
(@hello)
@tojok I already have ssh enabled once I connect pem I also loose ssh capability I will try it later to see if it says carrier lost if it does is it the pi or fan that's failty
Publié : 07/08/2023 7:34 pm
Hello
(@hello)
This is the fan https://www.raspberrypi.com/products/raspberry-pi-4-case-fan/
Hello
(@hello)
this is the logs Aug 8 15:49:41 prusa systemd[1]: rsyslog.service: Sent signal SIGHUP to main p>Aug 8 15:49:41 prusa systemd[1]: logrotate.service: Succeeded.Aug 8 15:49:41 prusa systemd[1]: Finished Rotate log files.Aug 8 15:49:42 prusa interesting_logger[585]: WARNING: Was[DEBUG]: Serial ERRO>Aug 8 15:49:42 prusa systemd[1]: man-db.service: Succeeded.Aug 8 15:49:42 prusa systemd[1]: Finished Daily man-db regeneration.Aug 8 15:49:44 prusa prusa.link.serial.serial_adapter[585]: WARNING: Error whe>Aug 8 15:49:48 prusa prusa.link.serial.serial_adapter[585]: WARNING: Error whe>Aug 8 15:49:52 prusa prusa.link.serial.serial_adapter[585]: WARNING: Error whe>Aug 8 15:49:55 prusa poorwsgi[585]: INFO: Digest: Authorization header not fou>Aug 8 15:49:55 prusa prusa.link.web.lib.classes[585]: INFO: 192.168.68.50 - "G>Aug 8 15:49:56 prusa prusa.link.serial.serial_adapter[585]: WARNING: Error whe>Aug 8 15:49:57 prusa prusa.link.web.lib.classes[585]: INFO: 192.168.68.50 - "G>Aug 8 15:49:57 prusa poorwsgi[585]: INFO: Return file: /main.44fd519fe74a820d5>Aug 8 15:49:57 prusa poorwsgi[585]: INFO: Return file: /main.97b8f9c3a3e4f0843>Aug 8 15:49:57 prusa prusa.link.web.lib.classes[585]: INFO: 192.168.68.50 - "G>Aug 8 15:49:57 prusa prusa.link.web.lib.classes[585]: INFO: 192.168.68.50 - "G>Aug 8 15:49:57 prusa poorwsgi[585]: INFO: Return file: /dfb811cc28f8e3d7c14bce>Aug 8 15:49:57 prusa poorwsgi[585]: INFO: Return file: /b891ace1622f34bac5a2b4>Aug 8 15:49:57 prusa poorwsgi[585]: INFO: Return file: /997c391425907810b4a6e4
Publié : 08/08/2023 4:08 am
Hello
(@hello)
1 other question how do i update prusalink without it loosing my setup
Publié : 08/08/2023 4:09 am
Tojik
(@tojik)
Membre Moderator
This log just says the serial is not connected. Nothing about the wifi. Also, the lines are incomplete...
Anyway. You said you have the latest prusalink from github. Do you mean the dev version or the latest image? If you got the latest image, an update without re-flashing should be finally possible once it's available.
Publié : 08/08/2023 6:21 am
Hello
(@hello)
0.7.0 my printer is connected via serial and works with prusalink
Publié : 08/08/2023 6:24 am
Hello
(@hello)
@tojik Is it something to be concerned about how it says serial not connected also logs taken from ssh not sure why uncompleted
Publié : 08/08/2023 6:26 am
Tojik
(@tojik)
Membre Moderator
You are looking at them through a CLI viewer. Likely a nano or less. You can scp the file to your local PC and view it in a text editor which would give you an easier time
Publié : 08/08/2023 6:30 am
Tojik
(@tojik)
Membre Moderator
Or you can copy the file through the prusalink web interface under settings. Or using filezilla
Hello
(@hello)
Oh I was using command prompt
Publié : 08/08/2023 6:31 am
Hello
(@hello)
@tojik never thought of getting it through web interface
Publié : 08/08/2023 6:32 am
Hello
(@hello)
@tojik should I be concerned aboutlogs saying serial port not connected
Tojik
(@tojik)
Membre Moderator
Yea, you might be running a command prompt for a terminal emulator, in there you run ssh that connects you to the pi, which is most likely running bash for a shell, which you used to view the file using a CLI text viewer or an editor like vi, nano, less, more and so on.
Publié : 08/08/2023 6:34 am
Hello
(@hello)
oh right thanks for clearing it up
Publié : 08/08/2023 6:55 am
Tojik
(@tojik)
Membre Moderator
Jesus, this is not discord. If you'd like discord style messaging. We have a Discord server. https://discord.gg/NbyfU7jx
Publié : 08/08/2023 7:07 am
Page 1 / 3
