PrusaSlicer doesn't open PrusaLink in its UI
Chris Young
(@chris-young-2)
Hi everyone,
I have been a long-time Octoprint user.  I have Prusa Slicer set up to send gcode directly to it and can even open the Octoprint UI from within the slicer by going to the physical printers tab.  Works great!
The other day I decided I would give PrusaLink a try.  Using the same pi, I built the image on an SD card and put it in the pi.  Everything works as expected.  Slicer sends gcode to the pi and my MK3 displays the filename, IP address, etc.  But what doesn't work is when I go to the physical printers tab in slicer I get an error  "Something Went Wrong".  Is this a known bug that is being worked on or do I have something misconfigured?  If it was the later, I would be having other issues with prusalink.  The prusalink interface works just fine and I'm able to print files that were uploaded via slicer, control the printer, etc.  Any help would be appreciated.
This shows what I see.  https://1drv.ms/v/s!ApEIZVkQ_KsXg9oOuhMZoptY649qng?e=w6IG8b
This topic was modified 8 months temu 2 times by Chris Young
Cheers
Chris
Opublikowany : 01/04/2025 6:15 pm
