					                		PrusaLink with Raspberry Pi 4 &amp; Pi Camera v3 disconnecting - Bugs &amp; Errors                                    </title>
                <link>https://forum.prusa3d.com/forum/bugs-errors/prusalink-with-raspberry-pi-4-pi-camera-v3-disconnecting/</link>
                <lastBuildDate>Wed, 22 Apr 2026 11:05:43 +0000</lastBuildDate>
                        <title>RE: PrusaLink with Raspberry Pi 4 &amp; Pi Camera v3 disconnecting</title>
                        <link>https://forum.prusa3d.com/forum/bugs-errors/prusalink-with-raspberry-pi-4-pi-camera-v3-disconnecting/#post-733362</link>
                        <pubDate>Tue, 21 Jan 2025 04:10:57 +0000</pubDate>
                        <description><![CDATA[PrusaLink type = Raspberry Pi 4  with Raspberry Pi Camera v3PrusaLink version = 0.8.1Printer type = Original Prusa i3 MK3S/+Printer UUID = 1634bcd7-07a8-4007-a2bf-f53495e3b53dPrinter firmwar...]]></description>
                        <content:encoded><![CDATA[<p>PrusaLink type = Raspberry Pi 4  with Raspberry Pi Camera v3</p><p>PrusaLink version = 0.8.1</p><p>Printer type = Original Prusa i3 MK3S/+</p><p>Printer UUID = 1634bcd7-07a8-4007-a2bf-f53495e3b53d</p><p>Printer firmware version = 3.14.1-8237</p><p>PrusaSlicer version = 2.9.0</p><p>Steps:</p><p>1. install prusalink 0.8.1 on sd card and connect to the printer IP</p><p>2. verified camera is detected in prusalink</p><p>3. reboot printer and raspberry pi</p><p>4. camera shows disconnected in prusalink</p><p>5. reinstalled prusalink 0.8.1 on sd card and setup prusalink and camera was working again.</p><p>6. reboot printer and raspberry pi and camera is not found. </p><p>Note: I ran 0.7.1rc1 and rebooted multiple times and the camera did not disconnect after reboots. </p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/bugs-errors/">Bugs &amp; Errors</category>                        <dc:creator>MontesDesigns.biz</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/bugs-errors/prusalink-with-raspberry-pi-4-pi-camera-v3-disconnecting/#post-733362</guid>
                        <link>https://forum.prusa3d.com/forum/bugs-errors/prusalink-with-raspberry-pi-4-pi-camera-v3-disconnecting/#post-733361</link>
                        <pubDate>Tue, 21 Jan 2025 03:07:31 +0000</pubDate>
                        <description><![CDATA[the only thing with running 0.7.1rc1 is no camera on the Prusa app. likely because that version is unaware it exists.]]></description>
                        <content:encoded><![CDATA[<p>the only thing with running 0.7.1rc1 is no camera on the Prusa app. likely because that version is unaware it exists. </p>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/bugs-errors/prusalink-with-raspberry-pi-4-pi-camera-v3-disconnecting/#post-733361</guid>
                        <link>https://forum.prusa3d.com/forum/bugs-errors/prusalink-with-raspberry-pi-4-pi-camera-v3-disconnecting/#post-733358</link>
                        <pubDate>Tue, 21 Jan 2025 02:28:19 +0000</pubDate>
                        <description><![CDATA[Running Prusalink 0.8.1When I load Prualink 0.7.1rc1 I don&#039;t have an issue after rebooting the pi and printer.]]></description>
                        <content:encoded><![CDATA[<p>Running Prusalink 0.8.1</p><p>When I load Prualink 0.7.1rc1 I don't have an issue after rebooting the pi and printer. </p>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/bugs-errors/prusalink-with-raspberry-pi-4-pi-camera-v3-disconnecting/#post-733358</guid>
                        <title>PrusaLink with Raspberry Pi 4 &amp; Pi Camera v3 disconnecting</title>
                        <link>https://forum.prusa3d.com/forum/bugs-errors/prusalink-with-raspberry-pi-4-pi-camera-v3-disconnecting/#post-733350</link>
                        <pubDate>Tue, 21 Jan 2025 00:18:52 +0000</pubDate>
                        <description><![CDATA[Hi Guys, I am having an issue with my Pi4 with PrusaLink and Pi Camera v3 disconnecting after I ran through the initial setup of PrusaLink and enabled the camera in Prusa Connect. I can see ...]]></description>
                        <content:encoded><![CDATA[<p>Hi Guys, </p><p>I am having an issue with my Pi4 with PrusaLink and Pi Camera v3 disconnecting after I ran through the initial setup of PrusaLink and enabled the camera in Prusa Connect. I can see the camera after the initial install and setup but when I reboot the pi or printer the camera does not come back but shows offline. I have ran the script in the ssh command to see if the pi is detecting the camera and it isn't. The only way to get it back is to reinstall PrusaLink but again If I shut down the printer and pi I lose the camera. </p><p>Thanks for your help!</p>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/bugs-errors/prusalink-with-raspberry-pi-4-pi-camera-v3-disconnecting/#post-733350</guid>
