PrusaLink not responding
I just upgraded to 0.7.0 from rc3, however i am facing the problem that prusalink is unresponsive and cannot be accessed by internal ip address, error occurs frequently and prevents me from uploading directly from prusaslicer, but it seems that PrusaConnect has no problem and it is still connected. I tried using ssh but still can't reach by ip address, i retried rc3 and found no problem, maybe there is a disconnect error prusalink but prusaconnect still works on new version 0.7.0
- Prusalink version 0.7.0
 - Type: Original Prusa i3 MK3S
 - Pi Zero W
 - Firmware: 3.12.2-5713
RE: PrusaLink not responding
Looks like the bug was fixed after several times re-flashing the prusalink
Hi. super weird. Would like to know some details. Hope we get someone that will post logs from the SD card. Did you by chance save anything? Sorry about the trouble
Not sure what happened, but i re-flashed the memory card so i couldn't extract the log file, however it seems that there's something wrong with my router that makes it impossible to access prusalink
