RE: PrusaLInk fails to boot with 3.13.0 and MMU2s 3.0.0.
No, the fix is that it will recognize the printer and not fail to run, not mmu tracking.
WI'll we get mmu3 errors what fillament it's at etc
Filament tracking is kinda impossible on the MK3. It does not say which preset did you choose on the LCD, or which filament is mentioned in the file from slicer when printing on SD. I will be able to see errors and maybe sometimes a selected slot and stuff. But a complete filament tracking sounds improbable. Idk, haven't tried to do it yet. Just temper your expectations
The lcd shows what slot its on it'd also be cool to show next fillament to be selected
Means looking ahead in the gcode (extra CPU load and sd reads), and I am not sure what would one doo with that information
Its handy to know next fillament anything can happen fillament could tangle accidentally gets pulled out of mmu3 etc
Yes, it is good to know once it's a problem, but one usually does not baby the print like that, you would not just sit there and maticulously look what the next filament loaded will be just to check on it
Thank you for the great information. Hopefully the updater will work as it should. firmware 3.13.0 is 80% more reliable for my MMU2S. It has small bugs, but satisfaction prevails. For me, it's a good job. Just understand me that for over a month I have to do all those MMU power off and on actions every time I reboot the printer.
Hello, are there any news about booting PrusaLink with MMU2s connected, running latest 3.13 firmware?
Ive had a few tangled spools so if I've got one loaded I'd like to know when that one is being selected
