					                		PrusaLink cannot connect to MK3S+ (3.14.0) on RPi Zero W (PrusaLink 0.8.1) - Bugs &amp; Errors                                    </title>
                <link>https://forum.prusa3d.com/forum/bugs-errors/prusalink-cannot-connect-to-mk3s-3-14-0-on-rpi-zero-w-prusalink-0-8-1/</link>
                <lastBuildDate>Fri, 12 Jun 2026 08:29:42 +0000</lastBuildDate>
                        <title>RE: PrusaLink cannot connect to MK3S+ (3.14.0) on RPi Zero W (PrusaLink 0.8.1)</title>
                        <link>https://forum.prusa3d.com/forum/bugs-errors/prusalink-cannot-connect-to-mk3s-3-14-0-on-rpi-zero-w-prusalink-0-8-1/#post-789197</link>
                        <pubDate>Mon, 13 Apr 2026 21:09:27 +0000</pubDate>
                        <description><![CDATA[This is probably almost a year too late, and not sure if this is the same problem as you, but I saw the same error message after taking the SD Card out of a Raspberry Pi 5 connected via USB ...]]></description>
                        <content:encoded><![CDATA[<p>This is probably almost a year too late, and not sure if this is the same problem as you, but I saw the same error message after taking the SD Card out of a Raspberry Pi 5 connected via USB to my mk3s and plugging it into a Raspberry Pi Zero 2. I think prusalink attempts to connect via USB by default, and I had to manually tell it to look at the right port (via GPIO):</p><pre contenteditable="false">jo@mk3s:~ $ cat /etc/prusalink/prusalink.ini
port = /dev/ttyS0</pre><p>Maybe this'll help someone!</p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/bugs-errors/">Bugs &amp; Errors</category>                        <dc:creator>nmattia</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/bugs-errors/prusalink-cannot-connect-to-mk3s-3-14-0-on-rpi-zero-w-prusalink-0-8-1/#post-789197</guid>
                        <link>https://forum.prusa3d.com/forum/bugs-errors/prusalink-cannot-connect-to-mk3s-3-14-0-on-rpi-zero-w-prusalink-0-8-1/#post-749118</link>
                        <pubDate>Thu, 08 May 2025 16:58:35 +0000</pubDate>
                        <description><![CDATA[I can confirm the behaviour OP described, it affects both my MKS3 and MKS3+ with my Raspberry Pi Zero W 1.1.Thank you @cookiecrook for bringing this up and providing a solution.Sad this anno...]]></description>
                        <content:encoded><![CDATA[<p>I can confirm the behaviour OP described, it affects both my MKS3 and MKS3+ with my Raspberry Pi Zero W 1.1.<br />Thank you @cookiecrook for bringing this up and providing a solution.</p><p>Sad this annoying bug persists for six month now.</p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/bugs-errors/">Bugs &amp; Errors</category>                        <dc:creator>wolffm</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/bugs-errors/prusalink-cannot-connect-to-mk3s-3-14-0-on-rpi-zero-w-prusalink-0-8-1/#post-749118</guid>
                        <link>https://forum.prusa3d.com/forum/bugs-errors/prusalink-cannot-connect-to-mk3s-3-14-0-on-rpi-zero-w-prusalink-0-8-1/#post-725112</link>
                        <pubDate>Tue, 22 Oct 2024 12:11:48 +0000</pubDate>
                        <description><![CDATA[I&#039;ve got an similar issue.I&#039;m using the following configuration:- Original Prusa i3 MK3S+ Bausatz- Raspberry Pi Zero for PrusaLink- Firmware3.14.0-8066- PrusaLink0.8.1There were no problems ...]]></description>
                        <content:encoded><![CDATA[<p>I've got an similar issue.</p><p>I'm using the following configuration:</p><p>- Original Prusa i3 MK3S+ Bausatz</p><p>- Raspberry Pi Zero for PrusaLink</p><p>- Firmware3.14.0-8066</p><p>- PrusaLink0.8.1</p><p>There were no problems when setting up the entire system. Even with the first 8-10 prints everything was fine. Only now, after switching on the printer, everything connects to PrusaLink, printing can be started but after half an hour to an hour the printer goes offline and printing stops. </p><p>What could be the probelm?</p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/bugs-errors/">Bugs &amp; Errors</category>                        <dc:creator>MM-SmartMachine GmbH</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/bugs-errors/prusalink-cannot-connect-to-mk3s-3-14-0-on-rpi-zero-w-prusalink-0-8-1/#post-725112</guid>
                        <link>https://forum.prusa3d.com/forum/bugs-errors/prusalink-cannot-connect-to-mk3s-3-14-0-on-rpi-zero-w-prusalink-0-8-1/#post-722351</link>
                        <pubDate>Fri, 20 Sep 2024 23:07:03 +0000</pubDate>
                        <description><![CDATA[A full downgrade of 0.8.1 to 0.7.2 resolved the issue... But then I updated again and it resolved itself in 0.8.1.Working assumption is that it was a bad restore in RPi Imager, but I don&#039;t h...]]></description>
                        <content:encoded><![CDATA[<p>A full downgrade of 0.8.1 to 0.7.2 resolved the issue... But then I updated again and it resolved itself in 0.8.1.</p><p>Working assumption is that it was a bad restore in RPi Imager, but I don't have a good explanation as to why it happened twice.</p><p>In any case, it's working for me now. in 0.8.1.</p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/bugs-errors/">Bugs &amp; Errors</category>                        <dc:creator>cookiecrook</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/bugs-errors/prusalink-cannot-connect-to-mk3s-3-14-0-on-rpi-zero-w-prusalink-0-8-1/#post-722351</guid>
                        <link>https://forum.prusa3d.com/forum/bugs-errors/prusalink-cannot-connect-to-mk3s-3-14-0-on-rpi-zero-w-prusalink-0-8-1/#post-722308</link>
                        <pubDate>Fri, 20 Sep 2024 13:49:32 +0000</pubDate>
                        <description><![CDATA[Never mind, figured it out. You have to run the wizard locally by going to your &quot;.local&quot; address first. You cannot add it to Prusa Connect with the &quot;Add Printer&quot; button like you can with the...]]></description>
                        <content:encoded><![CDATA[<p>Never mind, figured it out. You have to run the wizard locally by going to your ".local" address first. You cannot add it to Prusa Connect with the "Add Printer" button like you can with the other printers.</p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/bugs-errors/">Bugs &amp; Errors</category>                        <dc:creator>Razor</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/bugs-errors/prusalink-cannot-connect-to-mk3s-3-14-0-on-rpi-zero-w-prusalink-0-8-1/#post-722308</guid>
                        <link>https://forum.prusa3d.com/forum/bugs-errors/prusalink-cannot-connect-to-mk3s-3-14-0-on-rpi-zero-w-prusalink-0-8-1/#post-722304</link>
                        <pubDate>Fri, 20 Sep 2024 13:33:15 +0000</pubDate>
                        <description><![CDATA[Posted by: @b-o-b-3d-printing Hi, I do have kind of the same problem with the prusa link 0.8.1.I am into the point where my printer shows me the IP adress, but I cannot access it into my web...]]></description>
                        <content:encoded><![CDATA[<p> </p><blockquote data-userid="560467" data-postid="718563" data-mention="b-o-b-3d-printing"><div class="wpforo-post-quote-author"><strong> Posted by: @b-o-b-3d-printing </strong></div><p>Hi, I do have kind of the same problem with the prusa link 0.8.1.</p><p>I am into the point where my printer shows me the IP adress, but I cannot access it into my web browser...Do you solved your issue?</p></blockquote><p> </p><p>Same issue here. Were you able to fix this?</p>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/bugs-errors/prusalink-cannot-connect-to-mk3s-3-14-0-on-rpi-zero-w-prusalink-0-8-1/#post-722304</guid>
                        <link>https://forum.prusa3d.com/forum/bugs-errors/prusalink-cannot-connect-to-mk3s-3-14-0-on-rpi-zero-w-prusalink-0-8-1/#post-721120</link>
                        <pubDate>Sat, 07 Sep 2024 12:01:31 +0000</pubDate>
                        <description><![CDATA[Downgrading PrusaLink to 0.7.2 resolves the issue for me.]]></description>
                        <content:encoded><![CDATA[<p>Downgrading PrusaLink to 0.7.2 resolves the issue for me.</p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/bugs-errors/">Bugs &amp; Errors</category>                        <dc:creator>Christopher Frederickson</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/bugs-errors/prusalink-cannot-connect-to-mk3s-3-14-0-on-rpi-zero-w-prusalink-0-8-1/#post-721120</guid>
                        <link>https://forum.prusa3d.com/forum/bugs-errors/prusalink-cannot-connect-to-mk3s-3-14-0-on-rpi-zero-w-prusalink-0-8-1/#post-721075</link>
                        <pubDate>Fri, 06 Sep 2024 20:11:30 +0000</pubDate>
                        <description><![CDATA[I have the same issue.Have a new RPi Zero W purchased from the Prusa Shop. RPi port is on. MK3S firmware is 3.14.0-8066. PrusaLink 0.8.1.Getting the same: &quot;/dev/ttyAMA0:  NOT USABLE ......]]></description>
                        <content:encoded><![CDATA[<p>I have the same issue.</p><p>Have a new RPi Zero W purchased from the Prusa Shop. RPi port is on. MK3S firmware is 3.14.0-8066. PrusaLink 0.8.1.</p><p>Getting the same: "/dev/ttyAMA0:  NOT USABLE ... ✘" error.</p>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/bugs-errors/prusalink-cannot-connect-to-mk3s-3-14-0-on-rpi-zero-w-prusalink-0-8-1/#post-721075</guid>
                        <link>https://forum.prusa3d.com/forum/bugs-errors/prusalink-cannot-connect-to-mk3s-3-14-0-on-rpi-zero-w-prusalink-0-8-1/#post-718563</link>
                        <pubDate>Sun, 11 Aug 2024 19:15:24 +0000</pubDate>
                        <description><![CDATA[Hi, I do have kind of the same problem with the prusa link 0.8.1.I am into the point where my printer shows me the IP adress, but I cannot access it into my web browser...Do you solved your ...]]></description>
                        <content:encoded><![CDATA[<p>Hi, I do have kind of the same problem with the prusa link 0.8.1.</p><p>I am into the point where my printer shows me the IP adress, but I cannot access it into my web browser...Do you solved your issue?</p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/bugs-errors/">Bugs &amp; Errors</category>                        <dc:creator>B.o.B 3D Printing</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/bugs-errors/prusalink-cannot-connect-to-mk3s-3-14-0-on-rpi-zero-w-prusalink-0-8-1/#post-718563</guid>
                        <link>https://forum.prusa3d.com/forum/bugs-errors/prusalink-cannot-connect-to-mk3s-3-14-0-on-rpi-zero-w-prusalink-0-8-1/#post-717042</link>
                        <pubDate>Tue, 23 Jul 2024 02:01:42 +0000</pubDate>
                        <description><![CDATA[Of note, I&#039;m also experiencing another problem, which may be related.]]></description>
                        <content:encoded><![CDATA[<p>Of note, I'm also experiencing <a href="https://forum.prusa3d.com/forum/bugs-errors/after-installing-rpi-zero-prusa-mk3s-has-frequent-temporary-hangs-that-negatively-affect-print-quality-removing-rpi-resolves-the-issue/" target="_blank" rel="noopener">another problem, which may be related</a>.</p>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/bugs-errors/prusalink-cannot-connect-to-mk3s-3-14-0-on-rpi-zero-w-prusalink-0-8-1/#post-717042</guid>
