PrusaLink 404 SDCard is not Supported
Dan Nellessen
(@dan-nellessen)
If I try to add or delete print files from the local SD card plugged into the printer from PrusaLink/Connect, I get an "SD card not supported" error (PrusLink) or "Requested action has failed" error (PrusaConnect).  I get this for any SD card plugged into the printer.  None of the SD cards are in the Locked position.  I can view, queue and print files on the SD cards via PrusaLink/PrusaConnect, but not write or delete files.  Also, not sure if this related, but I haven't been able to stop/cancel a print started from an SD card through PrusaLink/PrusaConnect.  I don't get an error message.  The command just doesn't seem to work.  I have to hit the cancel button on the printer.
type Original Prusa i3 MK3S
firmware 3.11.0-4955
PrusaLink 0.6.1
PrusaConnect SDK 0.6.0
Best Answer by Tojik:
Hi, This is perfectly normal, the printer has the functionality for deletion of files, but there is no practical way to upload new ones to the SD card, the implementation present is shaky and terribly slow. Please use the Prusa Link storage instead.
Opublikowany : 22/07/2022 5:27 am
Tojik
(@tojik)
Member Moderator
RE: PrusaLink 404 SDCard is not Supported
Opublikowany : 22/07/2022 11:31 am
Dan Nellessen
(@dan-nellessen)
Thanks for confirming.  The option to perform write/deletion on the printer's SD card is present in Prusa Link/Connect, so I was concerned there was a bigger problem.  I thought it was a nice feature to clean up the files on the printer SD card remotely.  I'll continue with using the Prusa Link storage.  Thanks again!
Opublikowany : 22/07/2022 2:57 pm
Tojik
(@tojik)
Member Moderator
Okay, that might be broken, it should not present the buttons. Thank you for reporting
Opublikowany : 25/07/2022 9:03 am
