Prusa connect statistics issue
I have a small discrepancy in the stats where I use MMU3 and print different materials (not in the same project). For example, today I'm only printing PET-G material which is loaded in slot 5, but the stats say it is PLA.
My printer: MK4 + MMU3
Type: Original Prusa MK4
Firmware: 6.0.3+14902
Printer: UUID13dc4c3e-8e92-4f87-9d20-0fa4f15074e1x
I don't know if it can be also connected with prusa slicer, but there is version which is used: Version 2.8.0+win64
Is this something you can fix, or do we just have to live with it? Thanks for check.
RE: Prusa connect statistics issue
While cleaning my bgcodes in the printer, I noticed that some printed bgcodes have the wrong material. I am adding prinscreens. The material was PETG, and the settings in the gcodes (and also the material description in the gcodes) matched that. I think the stats (and list) don't account for the MMU and only use the first material in the MMU gcodes, because when I changed the material to PETG in the first position, even if I only print in the fifth position, the material is suddenly correct.
I believe I'm experiencing the same problem Extruder 1: PLA. Active print using only extruder 4 with ABS. PrusaSlicer shows ABS on extruder 4, the control panel on the PrusaXL shows ABS, but the dashboard in PrusaConnect shows the material to be PLA.
