Prusa Connect Keeps Showing Printer is Offline
Pagina 2 / 2
SCMemphis
(@scmemphis)
RE: Prusa Connect Keeps Showing Printer is Offline
So far this morning Prusa Connect has been working for me, no issues. Hopefully it stays like that. 🍺
Postato : 02/04/2025 1:23 pm
yodakubota
(@yodakubota)
Same. Connect is now working again when I checked on it this morning.
Posted by: @scmemphis
Postato : 02/04/2025 1:41 pm
3DMason
(@3dmason)
It's odd that it affects some & not others.  Wonder if it's related to the version of Wifi hardware are in people's printers.
Posted by: @dusanh
Same for me. But this behaviour is the same ever since I bought the printer ( January 2024 ).
Postato : 02/04/2025 4:00 pm
3DMason
(@3dmason)
Operational as of 9PM PST today.  However, all files have been mysteriously deleted from my USB memory stick.  Weird.
Postato : 02/04/2025 4:13 pm
Plastic Golem
(@plastic-golem)
Still an issue today (4th August) on latest alpha firmware on MK4S, mini+ and core one, on both wifi and Ethernet…
Postato : 04/08/2025 6:27 am
delianides
(@delianides)
To anyone that has this issue. I ended up emailing their app support. “[email protected]” and they were able to resolve the issue. Based on the way it was fixed I don’t believe this is an issue that will be resolved by a firmware update.
Postato : 04/08/2025 12:31 pm
3DMason
(@3dmason)
delianides; could you elaborate on how it was fixed or the root cause?
Postato : 15/08/2025 4:02 pm
LarryJ
(@larryj)
Same thing is happening with me.  It cuts off early in the printer cycle and does not come back on. Prusa Link still works fine.
Postato : 15/08/2025 7:45 pm
delianides
(@delianides)
I emailed [email protected]. They had to clear out the phantom printer. I ended up also removing the active printer because it never displayed any printer stats like temp or time remaining. I re-added the printer and all is well now.
Postato : 03/09/2025 12:11 pm
Petersman
(@petersman)
Utenti
I thing, the firmware update will fix that...
Read the comment to the upcomming firmware update
https://github.com/prusa3d/Prusa-Firmware-Buddy/releases/tag/v6.3.5-alpha
Postato : 07/09/2025 10:45 am
1 persone hanno apprezzato
Bob Z_i
(@bob-z_i)
Utenti
Hello, I can confirm the problem exists in version 2.9.4. There was no problem before the update.
(MK4S)
Pozdrawiam
Questo post è stato modificato 1 month fa da Bob Z_i
Postato : 14/12/2025 8:53 am
jiblett1000
(@jiblett1000)
Just sad. At least a year with this bug and it's still going on. Not sure why I paid like $1200 for a core one when I can't even print consistently on my local Wi-Fi connection.
Postato : 15/12/2025 10:41 am
Pagina 2 / 2
