PRUSA Connect Filament Spool states empty when it is not.
ajbooter
(@ajbooter)
PrusaLink type (Raspberry Pi Zero / Pi 3 / Pi 4) = Raspberry Pi Zero 2PrusaLink version = 0.6.1Printer type - MKS+Printer UUID (you can find it in Printer detail page - address line) = 3bc2ccf1-1a25-46f3-9213-afd9d8039d6dPrinter firmware version = 3.11.0-4955PrusaSlicer version (if applicable) = 2.4.2Description of the bug, including steps to reproduce (if possible).
I loaded the Filament using the Prusa Connect. In the RAW data, the information is available below. When I go to the Filament Tab I see the Spool I loaded and now it is empty. I had to restart a print 6 minutes into the print due to a dirty nozzle. Not sure why the spool says empty???
Thanks
{"name":"PrusaLinkA""firmware":"3.11.0-4955""created":1653590949"location":"A""sn":"MINE""uuid":"3bc2ccf1-1a25-46f3-9213-afd9d8039d6d""printer_type":"1.3.1""printer_type_name":"Original Prusa i3 MK3S""team_id":3050"team_name":"TEAM""prusa_link":"0.6.1""allowed_functionalities":[0:"files"1:"filament"2:"queue"]"rights_r":true"rights_w":true"rights_u":true"groups":[0:{...}]"state":"PRINTING""state_reason":"new state from event""job_info":{"origin_id":5"id":7"path":"/SD Card/Prusa/servic~4.gco - (service-parts-prusa-research-no-handle-top_0.3mm_PET).gcode""hash":"ziry4KKOmUz7o33DhcCVrNuFBGM.""start":1653668348"end":1653668349"progress":3"state":"PRINTING""time_printing":1320"time_estimated":31320}"axis_z":0.2"time_delta":0"network_info":{"wifi_ipv4":"IP.IP.IP.IP""wifi_mac":"MACATTACK""wifi_ssid":"NONO"}"flags":{"last_info_event":1653668349.3638763"last_file_tree_change":1653668349.4882636"last_printer_state_info":1653669685.2"last_online":1653669685.2"diverging_origin_id":false}"api_key":"A SECRET""sdk":"0.6.0""temp":{"temp_nozzle":239.8"temp_bed":84.7"target_nozzle":240"target_bed":85}"flow":95"speed":100"filament":{"id":2"color":"#FF6900""default":true"density":1270"team_id":0"material":"PETG""full_weight":1050"manufacturer":"Prusament""spool_weight":201"bed_temperature":80"nozzle_temperature":250}}
Posted : 27/05/2022 4:51 pm
Tojik liked
Tojik
(@tojik)
Member Moderator
RE: PRUSA Connect Filament Spool states empty when it is not.
Hi. We reset the spool weight on many different events, I would have made it say a questionmark, but the zero means the same thing.
If the job ends in an unknown state, if you print something with an unknown weight and more stuff like that all resets the tracked weight. I understand that that's far from ideal. Thank you for the detailed report
Posted : 31/05/2022 1:59 pm
ajbooter liked
ajbooter
(@ajbooter)
Thanks for the information. I am getting used to the software more and how it works. I do really like the interface as it is simple to use.
Posted : 07/06/2022 2:32 pm
