Printer often shows "Offline" in Prusa Connect
UjinDesign
(@ujindesign)
Hello.
I added my MK4 printer to Prusa Connect and Prusa Link a month ago. Prusa Link is working great but my printer keeps showing "Offline" on Prusa Connect. Sometimes the printer doesn't connect to Prusa Connect at all when turning it on, sometimes the printer loses connection seemingly randomly.
The only fix I've found is to turn off and on the printer again. I can't think of anything specific that I'm doing to trigger this bug. My printer is connected via WiFi, but the router is in the next room and the screen is showing full WiFi connectivity, so I don't think loss of internet connection is the issue. I start Prusa Connect via a web browser, not via PrusaSlicer.
PrusaLink type: I don't know. I just use the stock MK4 via WiFi.
PrusaLink version: I don't know...? This is Prusa Connect issue.
Printer type: MK4 (kit)
Printer UUID: https://connect.prusa3d.com/printer/05ae8c6c-5c28-4805-98c3-ace535471462/
Printer firmware version: 5.1.2+13478
PrusaSlicer version: 2.7.2 but I don't think this is relevant.
Napsal : 13/01/2024 2:07 pm
UjinDesign
(@ujindesign)
RE: Printer often shows "Offline" in Prusa Connect
I lost connection just now. I started a print via Prusa Link and monitored the progress for a minute on Prusa Connect. When checking back 10 mins later, the connection to Prusa Connect was lost. No interaction what-so-ever with the printer or any software during this period (no file uploads).
Napsal : 13/01/2024 2:24 pm
Tojik
(@tojik)
Member Moderator
Hi, this tends to happen for users logging in from a far, like the US or Australia and such. I am bringing this up periodically but so far we have not focused on this problem again. If you can, try connecting the printer to ethernet to see if anything changes. There is one much more involved solution i would like someone to try, but that's too much to ask as a troubleshooting step.
Also, when the printer becomes offline, is there an error shown in the settings -> network -> prusa connect submenu? What does it say?
Napsal : 15/01/2024 10:27 am
3DIsCool
(@3discool-2)
Is there something wrong with Prusa Connect's TLS certificates? I keep getting a TLS error when trying to connect my Mini+ (from the US).
$ curl -vI  https://buddy-a.connect.prusa3d.com
*   Trying 34.159.33.52:443...
* Connected to buddy-a.connect.prusa3d.com (34.159.33.52) port 443
* ALPN: curl offers h2,http/1.1
* (304) (OUT), TLS handshake, Client hello (1):
*  CAfile: /etc/ssl/cert.pem
*  CApath: none
* (304) (IN), TLS handshake, Server hello (2):
* (304) (IN), TLS handshake, Unknown (8):
* (304) (IN), TLS handshake, Certificate (11):
* SSL certificate problem: self signed certificate in certificate chain
* Closing connection
curl: (60) SSL certificate problem: self signed certificate in certificate chain
More details here:  https://curl.se/docs/sslcerts.html
curl failed to verify the legitimacy of the server and therefore could not
establish a secure connection to it. To learn more about this situation and
how to fix it, please visit the web page mentioned above.
I'm seeing a certificate which doesn't appear to be part of a chain back to one of the standard root CAs.
Thanks,
Andy
Napsal : 19/01/2024 6:06 pm
UjinDesign
(@ujindesign)
Posted by: @tojik
Hello, sorry for such a delayed answer.
I'm logging in from Sweden, my router and my computer isn't going via a VPN, so the distance to Czechia isn't that far!
I just tried this. I started the printer and confirmed via the printer settings that it was connected via ethernet. I checked Prusa Connect and my printer was online. I left it idle for a few hours and when I came back the printer was showing "offline" in Prusa Connect.
If the involved solution doesn't take too much IT-technical know-how and takes shorter than like 20 mins, I'd be happy to help.
Yes, there is an error. Both when I'm connected via WiFi and when I'm connected via ethernet, the "PRUSA CONNECT" menu says:
  • Enabled - [On]
  • Status - Connecting
  • Error - Refused
Napsal : 21/01/2024 1:25 pm
_KaszpiR_
(@_kaszpir_)
>Thanks,
>Andy
No, this is done on purpose, some printers have too low resources to support full CA chain in the processing, so the buddy-a.connect.prusa3d.com points to the address with different (simpler) cert (and AFAIR simpler encryption) so that connection is still secure.
Napsal : 21/01/2024 1:45 pm
1 lidem se líbí
Tojik
(@tojik)
Member Moderator
And if i can get off my butt, we can try the proxy thing. I just took on a task I have trouble finishing. And so trying stuff aside seems like a bad idea at the moment. Sorry
Napsal : 26/01/2024 11:48 am
UjinDesign
(@ujindesign)
Posted by: @tojik
No problem at all, take your time! ☀ I'm just glad if I can help solve the problem. I'll be here.
Napsal : 26/01/2024 7:49 pm
3DIsCool
(@3discool-2)
Interesting. I am still having intermittent issues with my Mini+ getting TLS errors. Any ideas why?
Napsal : 27/01/2024 3:43 pm
_KaszpiR_
(@_kaszpir_)
PrusaConnect website has performance issues, unfortunately.
Napsal : 27/01/2024 5:10 pm
