Power failure while printing (prusaconnect multi instance)
martin_pihrt
(@martin_pihrt)
I have 17x MK3 prusa 3D and control it via a Raspberry PI 3 (USB hubs to USB printers). I have RPI on UPS. If I am printing and there is a power failure of the printers, an error is displayed for the printers in prusa connect. This error cannot be removed (there is no button to silence the error). When the time for which the original object was supposed to be printed elapses, the error is unblocked and it can be printed as usual. The problem is that if the power goes out, nothing can be done until the printing time is virtually counted down.
Napsal : 29/05/2024 7:35 am
Marina Shepeleva
(@marina-shepeleva)
RE: Power failure while printing (prusaconnect multi instance)
Good afternoon, I have 10 printers and I have the same problem, I cannot start them remotely after power is restored, it raises the temperature of the bed, but the temperature of the nozzle does not, and as a result, an error occurs and there is no possibility to continue printing.
Napsal : 18/06/2024 6:10 am
