PiCamera v2(v3) issue (PrusaLink 0.7.0) with v4l2 error
Petr Sedlák
(@petr-sedlak)
Membre
I've been trying to figure this out for days. I'm not able to get the image using sudo libcamera-hello on PrusaLink 0.7.0 on RPI 3B+ (v1.2) with Picamera v3 (noir) or Picamera v2 (noir). This command will always raise an error. If I connect to prusaconnect, I don't even see the corresponding camera in the menu.
I have got V42L error for Picamera v2 (noir) :
[1288] ERROR V4L2 v4l2_device.cpp:353 'imx219 10-0010': Unable to set controls: Device or resource busy
[1288] WARN RPI raspberrypi.cpp:383 Mismatch between Unicam and CamHelper for embedded data usage!
I have got V42L error for Picamera v3 (noir) :
[939] ERROR V4L2 v4l2_device.cpp:353 'imx708_noir': Unable to set controls: Device or resource busy
Ofcourse  when I updated everything (even through rpi-update), I got the same results 🙁
I tried different HWs : I used different instances RPI 3B+ as well as different cables.
I tried different distributions: When I use official distribution BullEyes, it works perfectly and I got pictures by both cameras.
I suppose that it is something simple but I am stuck.
I would appreciate any meaningful answer.
thanks.
Best Answer by Tojik:
Hi, try running
prusalink stop
then try again with libcamera-hello. PrusaLink might be trying to grab them and failing, but it does not let go of them for some reason blocking libcamera-hello
if you can, try veryfying that prusalink really stopped using sudo htop.
Please send logs from prusalink - in the web interface under settings you should be able to download the syslog file. It is easier putting it on gdrive or something like it and sending a link, because the forum does not like large files and seems to bug out sometimes. Thank you
Publié : 25/08/2023 2:13 pm
_KaszpiR_
(@_kaszpir_)
RE: PiCamera v2(v3) issue (PrusaLink 0.7.0) with v4l2 error
can you provide details about below command:
cat /etc/os-release
on working and non-working setup?
Publié : 26/08/2023 6:19 am
Petr Sedlák
(@petr-sedlak)
Membre
it is the same 🙁
working
PRETTY_NAME="Raspbian GNU/Linux 11 (bullseye)"
NAME="Raspbian GNU/Linux"
VERSION_ID="11"
VERSION="11 (bullseye)"
VERSION_CODENAME=bullseye
ID=raspbian
ID_LIKE=debian
HOME_URL="http://www.raspbian.org/"
SUPPORT_URL="http://www.raspbian.org/RaspbianForums"
BUG_REPORT_URL="http://www.raspbian.org/RaspbianBugs"
nonworking
Publié : 28/08/2023 8:03 am
Tojik
(@tojik)
Membre Moderator
Hi, try running
prusalink stop
Publié : 28/08/2023 1:08 pm
_KaszpiR_
(@_kaszpir_)
you could compare working/non working /boot/config.txt - maybe there are extra dtoverlay libs enabled?
especially look for camera_auto_detect=1 and  start_x=1
https://www.raspberrypi.com/documentation/computers/config_txt.html
Next, make sure to re-run software install steps https://www.raspberrypi.com/documentation/accessories/camera.html#preparing-the-software
Also looks like those Arducam modules, so they may not be loaded automatically, and that may need extra steps to install modules for it:
- for imx219 - https://docs.arducam.com/Raspberry-Pi-Camera/Native-camera/Quick-Start-Guide/ - I suggest to start with this one.
- for imx708 - https://docs.arducam.com/Raspberry-Pi-Camera/Native-camera/12MP-IMX708/#software
Installs may differ slightly because they require different modules to load.
Also make sure you plugged properly cables and the cables are not broken (it is really easy to damage the edge of the ribbon, been there...)
Publié : 28/08/2023 1:22 pm
Tojik
(@tojik)
Membre Moderator
He himself says those are Raspberry Pi cameras. They share the same Sony sensor tho. Kinda puzzled by your response, but thanks for participating 🙂
Publié : 28/08/2023 3:22 pm
Petr Sedlák
(@petr-sedlak)
Membre
Thank you very much, Tojik.
Yes. PrusaLink was trying to grab them and failing. When I stopped prusalink, I was able to successfully acquire the image via libcamera-hello. Now I can see the image through prusalink, where I have it also turned on for prusaconnect.
The problem was, as in most cases, between the keyboard and the monitor. I'm a little embarrassed 🙂
Publié : 29/08/2023 7:05 am
Tojik
(@tojik)
Membre Moderator
You haven't seen the two months it took me to add them 😀 It's ok, glad they work now
Publié : 29/08/2023 10:47 am
John Smith
(@john-smith-4)
FYI,  I just integrated an IMX708 camera model B0312 from AduCam into a RPi 3B+ running PrusaLink.
I went to this website
and followed EVERY one of the steps below (yes, every step including the stuff for the RPi4 even though it is an RPi3):
For Raspberry Bullseye users running on Pi 4, please do the following:
sudo nano /boot/config.txt
#Find the line: camera_auto_detect=1,update it to: camera_auto_detect=0
dtoverlay=imx708
#Save and reboot.
For Bullseye users running on Pi 0 ~ 3, please also:
Open a terminal Run sudo raspi-config
Navigate to Advanced Options
Enable Glamor graphic acceleration
Reboot your Pi
If you encounter the display issues, please also execute the following steps:
Navigate to GL Driver
Select GL (Full KMS)
Reboot your Pi
Ce message a été modifié il y a 2 years par John Smith
Publié : 10/11/2023 11:31 pm
2 personnes ont aimé
Tojik
(@tojik)
Membre Moderator
PrusaLink has a camera whitelist. So please let me know if a new camera needs to be added. It has a whitelist because the libcamera library wants to detect even UVC stuff and that didn't work last time. Le whitelist: https://github.com/prusa3d/Prusa-Link/blob/ee1a1c3fe4cb333d6d4f786f8b35d6ed769834da/prusa/link/cameras/picamera_driver.py#L48
Publié : 13/11/2023 10:51 am
John Smith
(@john-smith-4)
I can confirm that my camera did not automatically configure and operate on my RPi 3B+ even though it is an "IMX708" as appears in picamera_driver.py#L48
I bought it from Amazon https://a.co/d/a8qJWfD as a "Arducam for Raspberry Pi Camera Module 3, 12MP IMX708 75°(D) Autofocus Pi Camera V3, 15-22pin FFC Cable"   Out of the box, my camera circuit board was stamped with a "Rev A" although there are newer Revs available.
In my instructions above, the camera started to operate after I performed the following step:
  • Select GL (Full KMS)
Perhaps the "Full KMS" must be loaded for some cameras to work?
Ce message a été modifié il y a 2 years 2 fois par John Smith
Publié : 13/11/2023 3:57 pm
_KaszpiR_
(@_kaszpir_)
Official Arducam docs for IMX708 mention this, so yes. https://docs.arducam.com/Raspberry-Pi-Camera/Native-camera/12MP-IMX708/#standard-autofocus-imx708-camera-module
Publié : 13/11/2023 8:57 pm
John Smith
(@john-smith-4)
Any way to automate the loading of "full KMS" when IMX708 is detected?
Publié : 13/11/2023 9:21 pm
_KaszpiR_
(@_kaszpir_)
not really, because it is a parameter required on device boot
Publié : 13/11/2023 10:08 pm
Tojik
(@tojik)
Membre Moderator
That sucks,
is there anything I can do to every image that would broaden the list of supported cameras?
Especially this - dtoverlay=imx708 looks like it might break compatibility with other sensors, but make your arducam work
Publié : 14/11/2023 9:55 am
_KaszpiR_
(@_kaszpir_)
Welcome to dtoverlay and hardware compatibility hell.
If it would be that easy it would be enabled by default
Publié : 14/11/2023 12:03 pm
