Moving a gcode to prusa link or printing from prusa connect - FORBIDDEN_READ_ONLY
PrusaLink type: Pi Zero W 2
PrusaLink version: 6.1
Printer type: Mk3s+
Uuid: e48c8b36-0566-47be-92bd-f34b472b48ea
Printer firmware version: 3.11.0-4955
Description:
I got 403 error from prusa link, when I want print from prusa connect or I want move gcode from prusa connect to prusa link.
Posted : 31/07/2022 10:25 am
RE: Moving a gcode to prusa link or printing from prusa connect - FORBIDDEN_READ_ONLY
Hello, please could you tell us, if:
- you has this problem from some specific time range, or if you has this problem from start using PrusaLink?
- is working uploading g-code directly to PrusaLink (throw internal Link web pages)?
- how many files you have on internal PrusaLink storage? is it possible, that you don't have enough space on it?
There is one another choice, simple your Micro SD card in PrusaLink is corrupted. That can be test, if you try write to SD card from PC, but working /boot section does not mean, that SD card is working. Best way is test secondary SD partition from some Linux system.
Posted : 02/08/2022 5:25 pm
