MK4 Prusa Connect Telematry
I have a MK4 that for the first day everything worked on Prusa connect now on connect it shows the printer is printing and the file its printing but no telemetry data or any of the files on the printer I have rebooted the printer and deleted it off connect and re added it but no change
RE: MK4 Prusa Connect Telematry
Yes that happend to me to today, no telemetry data and no files on the usb.
When I connect to the IP adres of the printer I see my files.
hum weird yes, i had it but today nope .!! that prusa server in his factory ..it was working perfectly yesterday , and by the way with the RPios and rambo it's useful and you can check your bed but with mk4 !! wonder me for what it's use !!
Under prusa connect it says net fail
I've been going crazy trying to fix this... same thing, net fail under Prusa Connect on the printer. Tried downgrading from 5.0.1 to 5.0.0, same error. MK3s seems fine though. Seems like something on their end then possibly.
Same Net Fails all the time I use these printers for a farm and the issues with octoprint and prusa connect are making me want to switch to a different printer
Could this be a bug in the 5.0.1 firmware maybe?
For me it is now working
funny enough it started working just after posting but now when I start a print from connect the printer gose into a homing axis loop that fails resets the printer then fails agin till i restat the printer and then start a print from the printer itself
