					                		Incorrect bed size Prusa Core One L in Prusa Connect web application - Bugs &amp; Errors                                    </title>
                <link>https://forum.prusa3d.com/forum/bugs-errors/incorrect-bed-size-prusa-core-one-l-in-prusa-connect-web-application/</link>
                <lastBuildDate>Thu, 21 May 2026 20:50:56 +0000</lastBuildDate>
                        <title>RE: Incorrect bed size Prusa Core One L in Prusa Connect web application</title>
                        <link>https://forum.prusa3d.com/forum/bugs-errors/incorrect-bed-size-prusa-core-one-l-in-prusa-connect-web-application/#post-778791</link>
                        <pubDate>Mon, 19 Jan 2026 19:21:53 +0000</pubDate>
                        <description><![CDATA[Hey. I checked and it&#039;s a confirmed and known issue, so a fix should be coming soon. I&#039;m not sure if the issue is on the firmware or connect side though, but I think it should be from connec...]]></description>
                        <content:encoded><![CDATA[<p>Hey. I checked and it's a confirmed and known issue, so a fix should be coming soon. I'm not sure if the issue is on the firmware or connect side though, but I think it should be from connect</p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/bugs-errors/">Bugs &amp; Errors</category>                        <dc:creator>Tommy_Prusa3D CM</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/bugs-errors/incorrect-bed-size-prusa-core-one-l-in-prusa-connect-web-application/#post-778791</guid>
                        <link>https://forum.prusa3d.com/forum/bugs-errors/incorrect-bed-size-prusa-core-one-l-in-prusa-connect-web-application/#post-776911</link>
                        <pubDate>Tue, 06 Jan 2026 19:19:02 +0000</pubDate>
                        <description><![CDATA[Yes, I have also the same problem, and yes it&#039;s very annoying.]]></description>
                        <content:encoded><![CDATA[<p>Yes, I have also the same problem, and yes it's very annoying.</p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/bugs-errors/">Bugs &amp; Errors</category>                        <dc:creator>DesignBy29</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/bugs-errors/incorrect-bed-size-prusa-core-one-l-in-prusa-connect-web-application/#post-776911</guid>
                        <link>https://forum.prusa3d.com/forum/bugs-errors/incorrect-bed-size-prusa-core-one-l-in-prusa-connect-web-application/#post-776806</link>
                        <pubDate>Mon, 05 Jan 2026 21:46:52 +0000</pubDate>
                        <description><![CDATA[Yes, I have the same problem, and it&#039;s very annoying. Could an administrator log in and fix it?]]></description>
                        <content:encoded><![CDATA[<p>Yes, I have the same problem, and it's very annoying. Could an administrator log in and fix it?</p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/bugs-errors/">Bugs &amp; Errors</category>                        <dc:creator>VladaT</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/bugs-errors/incorrect-bed-size-prusa-core-one-l-in-prusa-connect-web-application/#post-776806</guid>
                        <title>Incorrect bed size Prusa Core One L in Prusa Connect web application</title>
                        <link>https://forum.prusa3d.com/forum/bugs-errors/incorrect-bed-size-prusa-core-one-l-in-prusa-connect-web-application/#post-775171</link>
                        <pubDate>Sun, 21 Dec 2025 22:39:46 +0000</pubDate>
                        <description><![CDATA[My setup is a core one and core one L. when i use Prusa Connect from a browse, then the bed size on the Core One L is displayet as a core one. This is a problem when printning multiple items...]]></description>
                        <content:encoded><![CDATA[<p>My setup is a core one and core one L. <br />when i use Prusa Connect from a browse, then the bed size on the Core One L is displayet as a core one. <br />This is a problem when printning multiple items, and you want to skip items mid print (if items fails mid print). Then the numbers displayet are not matching the item that is printing.<br />I dont know if im the only one, that has this bug?</p><p>Bed size is correct in the Prusa connect app on Iphone and Ipad, but in that app i can not find any options to skip items mid print.</p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/bugs-errors/">Bugs &amp; Errors</category>                        <dc:creator>Brian</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/bugs-errors/incorrect-bed-size-prusa-core-one-l-in-prusa-connect-web-application/#post-775171</guid>
