Incorrect bed size Prusa Core One L in Prusa Connect web application
Brian
(@brian-17)
Miembro
My setup is a core one and core one L.
when i use Prusa Connect from a browse, then the bed size on the Core One L is displayet as a core one.
This is a problem when printning multiple items, and you want to skip items mid print (if items fails mid print). Then the numbers displayet are not matching the item that is printing.
I dont know if im the only one, that has this bug?
Bed size is correct in the Prusa connect app on Iphone and Ipad, but in that app i can not find any options to skip items mid print.
Respondido : 21/12/2025 10:39 pm
2 les gusta
VladaT
(@vladat)
RE: Incorrect bed size Prusa Core One L in Prusa Connect web application
Yes, I have the same problem, and it's very annoying. Could an administrator log in and fix it?
Respondido : 05/01/2026 9:46 pm
DesignBy29
(@designby29)
Miembro
Yes, I have also the same problem, and yes it's very annoying.
Esta publicación ha sido modificada el hace 4 months por DesignBy29
Respondido : 06/01/2026 7:19 pm
Tommy_Prusa3D CM
(@tommy_prusa3d-cm)
Miembro Admin
Hey. I checked and it's a confirmed and known issue, so a fix should be coming soon. I'm not sure if the issue is on the firmware or connect side though, but I think it should be from connect
Respondido : 19/01/2026 7:21 pm
