If you wait too long to change filament after a pause the print will not continue
Seite 2 / 2
RE: If you wait too long to change filament after a pause the print will not continue
I think this may be an issue with Prusa Link or Prusa Connect.
I believe this way of working removes autonomy from the printer.
Sorry I can't help further.
I hope someone else can help
Joan
Veröffentlicht : 03/04/2022 9:53 pm
Tojik
(@tojik)
Mitglied Moderator
Hi, I would need more info to diagnose this. What version are you on? And if it's the hotfix or newer, which it looks like it is, could you send logs from that day? It will be in the local web interface under settings. I am interested in the syslog, syslog.1 ,or syslog.2.tgz. Whatever the extension is. The older logs get compressed, so only the two newest are available for viewing right away. You can check which one contains the date of the incident and just send me that one. Thank you
Veröffentlicht : 04/04/2022 8:48 am
Tojik
(@tojik)
Mitglied Moderator
Ooooh I misread that, yes, the issue you're experiencing is the one fixed by the hotfix. But please download the 0.6.1
Veröffentlicht : 04/04/2022 8:51 am
kohend
(@kohend)
Mitglied
Turns out I did use the hotfix version, just checked in the about dialog.
I'll see if these logs are still available.
Veröffentlicht : 05/04/2022 3:20 pm
Seite 2 / 2
