"Errors resolved"?
"Errors resolved"?
I just noticed that in the middle of a print the printer goes beep beep beep and a message on the LCD display pops up "Errors resolved". Print continues just fine, with no visible issues.
No idea what that error message means. Nothing in the PrusaConnect log files.
Respondido : 13/11/2022 6:38 pm
RE: "Errors resolved"?
I should have noted, it's a Mk3S+, with Prusalink on a Raspi 3b
Respondido : 13/11/2022 6:45 pm
Tojik
(@tojik)
Miembro Moderator
Hi, yes, this is an annoying issue. The request with telemetry gets stuck somewhere. After it times out, it trips my error detection, that does its thing and notifies every component about the issue, which makes the printer beep. Immediately after, the next telemetry goes through without issue, so the error component just reports everything being functional again and moves on. I have to make a better error observation, so some errors need to be valid for a longer time before sounding the alarm. Also, the sound needs a mute switch somewhere. Thank you for reporting
Respondido : 14/11/2022 4:40 pm
No problem. Glad to hear it's not actually any serious issues.
Respondido : 14/11/2022 5:06 pm
Patrick.b
(@patrick-b)
Posted by: @fuchsr
hi, well same issue since few days , during print or no prin beep and solved but nothing appears on prusaconnect ...so wierd but not so bad
Respondido : 24/11/2022 1:16 pm
Yeah, sometimes there's a cacophony of sounds from my two Mk3S running Prusalink… weird but apparently without any negative effects,
Respondido : 24/11/2022 2:59 pm
1 les gusta
Tojik
(@tojik)
Miembro Moderator
Just implemented a workaround to silence this. Here's hoping it won't introduce any other problems 😁
Respondido : 24/11/2022 3:30 pm
kobbler
(@kobbler)
I am getting the 3 beeps and "errors resolved" after upgrading an mk3s+ to 0.7.0rc2 on a Pi Zero 2W.  I don't recall seeing it with 0.6.1.
Not sure if its related but I am no longer able to "send to printer" from PrusaSlicer as I get an API error. The printer works normally in PrusaConnect and PrusaLink. The API matches in PrusaConnect and PrusaSlicer. I'll try to reset the API in PrusaLink tomorrow after the current print completes.
Respondido : 13/02/2023 11:53 pm
Tojik
(@tojik)
Miembro Moderator
Hi, try switching the physical printer to digest authentication. The beeps are unrelated and plagueing this version super hard. Sorry about them 😖
Respondido : 14/02/2023 12:27 am
kobbler
(@kobbler)
Thanks Tojik!
Digest authentication worked. Resetting the API did not.
Respondido : 15/02/2023 2:34 am
1 les gusta
Patrick.b
(@patrick-b)
Hi Tojik ,
any news about this printer beep ? as these days, i have almost not 1 during print , but at end i mean when print done, it's beeping a lot and sure error solved ..apparently but not sure IF i run prusaconnect then beep stop !! as  i only use the prusa link ..thx
Respondido : 13/04/2023 11:56 am
Ray
 Ray
(@ray-3)
Miembro
I was having this issue using rc3 on only 1 mk3s+ with a 3b  my 2 other mk3s+ with pi zeros had no issues.  until today.  All my printers now show a http error.
Me being the person I am I reflashed the 2 pi zeros with the prusa link rc 2.  now I cannot register those to printers with prusa connect.  I just get Can't resolve Prusa Connect hostname.
Respondido : 23/04/2023 11:42 pm
(((GRIFFCOMM
(@griffcomm)
Am here for a similar reason, is PrusaConnect down?
Many Thanks
Respondido : 24/04/2023 3:06 am
Tojik
(@tojik)
Miembro Moderator
Yup, that seems to have been the case. Sorry :/
Respondido : 24/04/2023 9:02 am
