Deleted file appears again after restart
mike4001
(@mike4001)
Miembro
The first ever gcode-file I uploaded via PrusaConnect appears again every time I start the printer.
It seems that it get´s downloaded again but I don't know why or from where.
It does not matter if I delete the file directly from the SD card or via PrusaConnect.
Once I start the printer again it appears again in my printable files.
Is there a solution for this?
Respondido : 01/09/2023 11:46 am
Tojik
(@tojik)
Miembro Moderator
RE: Deleted file appears again after restart
Hi, do you see the file appear in local PrusaLink as well?
Respondido : 04/09/2023 2:06 pm
mike4001
(@mike4001)
Miembro
Hello,
I think I could solved the problem.
I deleted the file from https://connect.prusa3d.com/storage/connect as well and now it does not get downloaded again to my machine.
Respondido : 04/09/2023 2:24 pm
1 les gusta
RickM
(@rickm-3)
Hopefully this solves a reappearing file issue we've had as well.
Thanks!
Respondido : 11/11/2024 11:29 pm
cabbage63
(@cabbage63)
I have had the same issue as well. I kept looking for the source of it and eventually I found it, somehow I had inadvertently added a file to the "print queue" in the prusa slicer and it would show up every time I turned the printer on. Try checking there and delete that, it worked for me.
Respondido : 13/11/2024 5:05 pm
1 les gusta
RickM
(@rickm-3)
I deleted the Connect files as @Mike4001 suggested and thus far the file hasn't returned.  Could be it was in print queue and deleting it also removed it from print queue.  Either way Thanks!
Respondido : 13/11/2024 5:44 pm
