					                		Buddy3D Camera: Timelapse setting resets after each reboot - Bugs &amp; Errors                                    </title>
                <link>https://forum.prusa3d.com/forum/bugs-errors/buddy3d-camera-timelapse-setting-resets-after-each-reboot/</link>
                <lastBuildDate>Wed, 13 May 2026 01:36:02 +0000</lastBuildDate>
                        <title>RE: Buddy3D Camera: Timelapse setting resets after each reboot</title>
                        <link>https://forum.prusa3d.com/forum/bugs-errors/buddy3d-camera-timelapse-setting-resets-after-each-reboot/#post-763430</link>
                        <pubDate>Fri, 05 Sep 2025 08:44:02 +0000</pubDate>
                        <description><![CDATA[Prusa just released a new version of Prusa Connect, and the camera settings are now also visible there - not only in the mobile Prusa app.On the desktop version, a “Job name” is required. I ...]]></description>
                        <content:encoded><![CDATA[<p data-start="144" data-end="284">Prusa just released a new version of Prusa Connect, and the camera settings are now also visible there - not only in the mobile Prusa app.</p><p data-start="286" data-end="606">On the desktop version, a “Job name” is required. I believe Prusa intentionally disables the flag for each new print, whereas I would expect the setting to stay enabled once it has been turned on. It’s probably just a misunderstanding of how the feature is meant to work, since there isn’t much information about it.</p><p data-start="608" data-end="864">In any case, I assume it works as intended, though it’s not very user-friendly. It’s also a bit of a pity that some settings and views are only available in the mobile app, while others (e.g. cancelling objects) are only available in the desktop version.</p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/bugs-errors/">Bugs &amp; Errors</category>                        <dc:creator>samuel-t</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/bugs-errors/buddy3d-camera-timelapse-setting-resets-after-each-reboot/#post-763430</guid>
                        <title>Buddy3D Camera: Timelapse setting resets after each reboot</title>
                        <link>https://forum.prusa3d.com/forum/bugs-errors/buddy3d-camera-timelapse-setting-resets-after-each-reboot/#post-763393</link>
                        <pubDate>Thu, 04 Sep 2025 19:36:28 +0000</pubDate>
                        <description><![CDATA[HiI added a Mini-SD card to my Buddy3D Camera and enabled the setting “Timelapse → Permanent timelapses on SD card”. However, this setting resets (switches off) after every Buddy3D Camera re...]]></description>
                        <content:encoded><![CDATA[<p data-start="79" data-end="278">Hi</p><p data-start="79" data-end="278">I added a Mini-SD card to my Buddy3D Camera and enabled the setting “Timelapse → Permanent timelapses on SD card”. However, this setting resets (switches off) after every Buddy3D Camera reboot.</p><p data-start="280" data-end="315">Can anyone confirm this behavior?</p>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/bugs-errors/buddy3d-camera-timelapse-setting-resets-after-each-reboot/#post-763393</guid>
