Any way to change the printer name in Prusa Connect?
N1FIY
(@n1fiy)
I recently setup my Mk4 with Prusa Connect, and everything seemed great, until of course I realized that the iPhone I was using to configure the printer autocorrected the printer name to something else.  I'm not seeing a way in the software or on the printer to rename the printer, and searching the archives has also come up blank.  Wondering if there is an easy way to do this, and if not, maybe a hard way?  Thanks.
Posted : 28/10/2024 11:43 pm
_KaszpiR_
(@_kaszpir_)
RE: Any way to change the printer name in Prusa Connect?
Go to the website of Prusa Connect, select given printer, go to settings and there you can rename the printer.
Posted : 29/10/2024 8:18 am
Or in the Prusa app on iOS, select the printer, click on the gear icon, then the arrow next to the printer name, and it will also take you to the website to change the name.
Posted : 29/10/2024 11:53 am
N1FIY
(@n1fiy)
Awesome, thank you so much.  Worked exactly as I hoped!
Posted : 29/10/2024 7:53 pm
N1FIY
(@n1fiy)
Thanks, that also looks like it will work.  I used the first suggestion, but will keep this in mind for the future.
Posted : 29/10/2024 7:54 pm
