RE: 0.5.2 Documentation missing for USB and non Zero Pi
Terminal
Is there an alternative to Putty for Mac users?
On MacOS you can just open a terminal. from the terminal, you can directly use ssh.
ssh pi@ipaddress
for instance: ssh [email protected] if your prusalink has 192.168.0.100 as IP address
I have no special talent. I am only passionately curious
I have a pi 3b+ connected to a buck converter for power, can I connect via GPIO ?
oops nevermind i forgot to enable RPi Port in the menu (facepalm)
Thanks for pointing that out, also
CTRL + SHIFT + X to get into advanced options in the Pi Imager, there's no button or menu item which is weird.
Yes, you will need to use the Raspberry Pi Imager software advanced settings to allow for SSH.
hey.
i cant connect via SSH. is there any option you need to activate on the sd card before using SSH?
Error Message: "Network Error: Connection refused"
Might need a sudo or two in there for mkdir and touch.
Can you elaborate on "a sudo or two", I'm not the best with programming so I'm not sure how to do this.
sudo touch prusa-link.inipi@prusa:/etc
sudo nano prusa-link.ini Not programming, *nix privilege escalation 🙂
Nice. One of us really needs to do a quick and dirty dead nuts correct document for USB connect.
Donât trust forum advice.
Folks - This applies to release 0.6.0 also. Note: When installing Prusa-Link on your SD card, make sure you check the box to enable SSH and set a password. Rest of the instructions for RPI3/4 can be found in this related post on the forum:
https://forum.prusa3d.com/forum/introcuctions-instrutctions/raspberry-pi4/#post-552325
A neat trick for the Pi is to put a file called "ssh" on the boot partition of the SD. That turns on SSH (and the file gets deleted)
just thought i'd take a crack at it but no dice for me. Prusalink 0.6.0
trying prusalink.local tells me firmware is not up to date. was forced to update from 3.10.0 to 3.10.1 still nothing.
i tried using the local IP assigned nothing. im not sure if its my ip, because when i boot the pi image with a monitor, i see that it has been assigned an ip address.
Are you able to see the printer as a USB device on the raspberry pi? e.g.
$ lsusb -v
Are you able to connect to the printer ok with the same USB cable on a computer? Try connecting the cable to a different USB port of the Raspberry Pi.
$ lsusb -vAre you able to connect to the printer ok with the same USB cable on a computer? Try connecting the cable to a different USB port of the Raspberry Pi.
Bus 001 Device 004: ID 2c99:0002 Prusa Original Prusa i3 MK3
Couldn't open device, some information will be missing
Device Descriptor:
bLength 18
bDescriptorType 1
bcdUSB 2.00
bDeviceClass 2 Communications
bDeviceSubClass 0
bDeviceProtocol 0
bMaxPacketSize0 8
idVendor 0x2c99 Prusa
idProduct 0x0002
bcdDevice 1.30
iManufacturer 1 Prusa Research (prusa3d.com)
iProduct 2 Original Prusa i3 MK3
iSerial 3 CZPX4920X004XK37005
bNumConfigurations 1
Configuration Descriptor:
bLength 9
bDescriptorType 2
wTotalLength 0x003e
bNumInterfaces 2
bConfigurationValue 1
iConfiguration 0
bmAttributes 0xc0
Self Powered
MaxPower 100mA
Interface Descriptor:
bLength 9
bDescriptorType 4
bInterfaceNumber 0
bAlternateSetting 0
bNumEndpoints 1
bInterfaceClass 2 Communications
bInterfaceSubClass 2 Abstract (modem)
bInterfaceProtocol 1 AT-commands (v.25ter)
iInterface 0
CDC Header:
bcdCDC 10.01
CDC ACM:
bmCapabilities 0x06
sends break
line coding and serial state
CDC Union:
bMasterInterface 0
bSlaveInterface 1
Endpoint Descriptor:
bLength 7
bDescriptorType 5
bEndpointAddress 0x82 EP 2 IN
bmAttributes 3
Transfer Type Interrupt
Synch Type None
Usage Type Data
wMaxPacketSize 0x0008 1x 8 bytes
bInterval 255
bLength 9
bDescriptorType 4
bInterfaceNumber 1
bAlternateSetting 0
bNumEndpoints 2
bInterfaceClass 10 CDC Data
bInterfaceSubClass 0
bInterfaceProtocol 0
iInterface 0
bLength 7
bDescriptorType 5
bEndpointAddress 0x04 EP 4 OUT
bmAttributes 2
Transfer Type Bulk
Synch Type None
Usage Type Data
wMaxPacketSize 0x0040 1x 64 bytes
bInterval 1
bLength 7
bDescriptorType 5
bEndpointAddress 0x83 EP 3 IN
bmAttributes 2
Transfer Type Bulk
Synch Type None
Usage Type Data
bInterval 1
i was able to update my Mk3s+ firmware using same cable.
I expect you have created the config file specifying the port /dev/ttyACM0 like OP explained, if yes, then the only option I can think of is to go through the logs looking for the port it's using and what's it unhappy about.
The log is at /var/log/daemon.log, there might not be enough detail there, but we'll deal with that once we get to it
Yes i have
[printer]
port=/dev/ttyACM0
baudrate=115200
Will check logs asap.
NOW im getting somewhere.. i decided to redo everything and i am now at Prusa Connect Settings.
i get a "Can't resolve Prusa Connect hostname." error with hostname = connect.prusa3d.com
i have the port at default = 0
What are you currently using to connect to the webGUI? The hostname or IP address of the Pi?
I know that the default port is 0 (e.g. 8080) once the system is configured. Did you also happen by chance to change any additional settings when configuring the PrusaLink using the RasPi Imager? (Change the default user from “pi”?) which may cause the setup to stop working.
I would personally also try to restart the setup process again with an incognito/private browser window… as I found that useful features such as Autofill mess up the configuration process.
looks like i got it setup.
i was connecting with Prusalink.local. when i tried connecting with my local ip address, voila! now to figure out how this thing works. im now looking into how to send a file to print.
thank you very much.
The fact that your MK3 reboots when you boot the pi does sound promising.
Yes and the Pi also stops, without shutdown process, when you turn the printer off.
Yup, it's same as octoprint on zero and yes, I'd like to make it a little smarter too
All the more reason to connect via usb. For just the cost of a usb data cable, and a usb power supply, which may already exist in your pile of electronic leftovers. And, no soldering of headers, after, of course finding the right headers, and trimming off the interfering pins.
Puzzling to me that we have plans to hard mount a $10 32 bit computer which is more powerful than the recipient. USB was created by smart people, to solve problems like this.
