Every 2nd Image is dark
Grisu
(@grisu)
I've installed my Buddy3D-Camera. If there is enough light (color mode) - everything is fine.
But if it's dark (Printer is installed in basement - normaly it's dark during the print), i've got every 2nd image as a dark image:
Normal:
Dark:
Everybody else with this behavior? Any solutions? if not i'll write to Prusa support...
Posted : 28/12/2024 6:40 pm
Heiko Gloeckler
(@heiko-gloeckler)
I experienced the same problem. Even when pointing the camera to the complete dark room, the picture changes betwenn IR and standard !
For now I did a complete reset of the camera (push-button for 5 seconds) an readopted the camera, it seems to work but I will need to try it in the dark again to be sure. Seems to be some kind of firmware problem with light metering and turning on/off IR.
Posted : 15/01/2025 9:10 am
Heiko Gloeckler
(@heiko-gloeckler)
RE: Every 2nd Image is dark
After contacting support I received a new camera from Prusa and had no other problems any more ! Seems the IR-filter/sensor was kind of defect.
Posted : 03/02/2025 1:15 pm
Grisu
(@grisu)
Thanks for your feedback! Will try to reset too the camera - otherwise i'll contact the support
Posted : 07/04/2025 12:41 pm
