Core One Buddy Camera Forgets Network Data
ShaneG
(@shaneg)
Hi I just set up the buddy camera for my Core One. I power the printer off when not in use and when I do the camera forgets the network data and has to be reconnected each time with a QR code.
Using firmware v3.0.4
Is this a bug or a feature?
Posted : 18/04/2025 3:57 am
LarGriff
(@largriff)
Assuming the camera is still powered, it stops taking snapshots when the printer is OFF.  After you turn the printer on, the camera will automatically resume taking snapshots every 10-11 seconds.
2022 - Creality Ender 3 V2
2024 - Prusa MK4S/MMU3
2026 - Bambu P2S/AMS2Pro
Posted : 19/04/2025 4:23 pm
ShaneG
(@shaneg)
RE: Core One Buddy Camera Forgets Network Data
The camera is powered by the printer, so if I power off the printer the camera powers off too.
When I power the printer back on the camera doesn't reconnect to my wifi network, I need to rescan the QR code. I assume from your answer that this is not the intended behaviour.
Posted : 19/04/2025 4:59 pm
LarGriff
(@largriff)
Sorry, I didn’t notice that you’re using it on a CoreOne; mine is on a MK4S.  It’s basically the same camera in a different housing, except that on a MK4S it has to be powered separately.  Just a suggestion, but you might try powering the camera from a separate supply, at least temporarily, and see what happens when you turn the printer on & off.
My camera automatically reconnects after power cycling either the printer alone, the camera, or both, so that’s what yours *should* do.  It is v3.0.4.
Posted : 20/04/2025 1:13 pm
rphughesnj@icloud.com
(@rphughesnjicloud-com)
I experienced the same reconnect problem.  Exchanged email with support.  They finally sent me a replacement camera.  The replacement has the same “failure to reconnect” problem.  Very frustrating.  After playing around with the problem I finally gave up and I am installing an Octopi camera setup instead.
Posted : 23/04/2025 2:44 am
TubularNut
(@tubularnut)
Just setup my camera which came with an assembled Core One, it also forgets the network after a power off.
Firmware Version 3.0.4
NB. I also had trouble with a $ in the password, had to setup a separate network for it with a different password.
Posted : 25/04/2025 6:35 pm
Paul
 Paul
(@paul-33)
I found a solution for the problem. Start with a reset of the camera and delete it also in prusa connect. Then scan the QR code to register it. After that register it again with s new QR code. Then you should have 2 cameras in prusa connect. It is now working as it was supposed to also after a power cycle. Dont aks me why 🙂
Now i just deleted the first registered camera and everything is working since then.
Hope this is also working for you. FW 3.0.4
Posted : 09/05/2025 4:57 pm
StanleyB
(@stanleyb)
I had the same problem and I found a solution - at least with my camera.
I just put any micro SD card in it.
From then on the camera logs into the network and plays a melody.
BTW. No instructions say that hmmmm...
Posted : 06/06/2025 6:14 pm
3 people liked
JusParadus
(@jusparadus)
This fixed my camera. Thanks.
Posted by: @stanleyb
Posted : 14/06/2025 4:04 pm
