Another "this image is older than 1 hour"
Misancal
(@misancal)
We have one Prusa MK4s with enclosure with a buddy camera close to a Prusa Xl with enclosure with another buddy camera. Both are connected to the same Wifi. The camera on the Mk4s gives us no problems at all, always showing image. However, the one on the Prusa Xl always shows "this image is older than 1 hour" after some time, no matter if the printer is working on not. I tried to reset the camera, disconnect it and connect it again. And after some minutes or hours showing images, it goes back to "this image is older than 1 hour". Anyone has an idea to solve this?
Posted : 17/11/2025 4:30 pm
Niek09
(@niek09)
RE: Another "this image is older than 1 hour"
Updated to 3.1.2 here as well and got the same problems. Never had a problem before besides the camera only accepting 2.4 GHz. Now I can connect it but after a reboot it does not work anymore. It says "Wifi connection failed".
Posted : 28/11/2025 9:54 pm
mute
 mute
(@mute)
Same thing here — this camera went from working pretty well to being mostly useless. I’ve re-paired the camera several times and it will update the still photos for a little while, then never again. In app, I can see the live feed, but that’s it.
Please get this fixed — I was on the fence about buying this camera because I hate the form factor, but I gave up waiting for a Connect supported camera and bought one. I was happy initially, but I’m close to relegating it to the junk box.
Posted : 29/11/2025 8:56 pm
Rob Nee
(@rob-nee)
I have never gotten the Buddy3D working reliably enough to be able to tell if the 3.1.2 update is a problem or not. The camera has the weakest wifi performance of any device I have ever used. It can't get a stable signal from the access point that is 12 feet away. I resorted to a separate 2.4GHz network just for the Buddy3D served from a router that is 1 foot from the camera. This has been a little more reliable but the camera goes dead even with this setup. The access point will show that the camera is still connected but dopey PrusaConnect will say it's no longer connected. Only unplugging the camera and plugging it back it will restore it.
Posted : 30/11/2025 2:56 pm
