Timelaps Buddy 3D
Hallo wollte mal fragen ob mal bald nen update rauskommt, das man auch timelaps erstellen kann.
da ja auf der Homepage steht das daran gearbeitet wird.
weil viele andere druckerhersteller können das ja alles ohne probleme.
mfg
RE: Timelaps Buddy 3D
I too am interested in the Timelapse function as described in the BuddyCam Feature Timeline. An SD Card is mentioned. Is that shipped with the camera, or do need to order that ourselves? Recommended minimum capacity?
Hello, I wanted to ask if an update will be released soon that will allow you to create timelapses.
Since the website says they're working on it, many other printer manufacturers can do this without any problems.
mfg
You supply your own micro SD card. I happened to have a 128gb card, so that's what I used, but it's certainly too big for my use. The individual frames are 170 KB or so, depending on the compression.
I bought and installed a 256GB card. I reinitialized the camera. I configured the camera to take time lapse pics. Other than physically pulling the card, is there a way to download them?
Not that I know of. I pulled the card and copied the files to my computer. It's certainly not convenient, but at this point I'm just happy to have some new features.
Maybe in the future they will implement a way to download the files via Connect.
Hi
You can also capture the live stream from a dedicated machine
Check out this post:
https://forum.prusa3d.com/forum/postid/756194/
