					                		Hinged Lid and Advanced Filtering system - Assembly and troubleshooting                                    </title>
                <link>https://forum.prusa3d.com/forum/assembly-and-troubleshooting/hinged-lid-and-advanced-filtering-system/</link>
                <lastBuildDate>Fri, 12 Jun 2026 04:56:41 +0000</lastBuildDate>
                        <title>RE: Hinged Lid and Advanced Filtering system</title>
                        <link>https://forum.prusa3d.com/forum/assembly-and-troubleshooting/hinged-lid-and-advanced-filtering-system/#post-717987</link>
                        <pubDate>Sat, 03 Aug 2024 23:12:56 +0000</pubDate>
                        <description><![CDATA[I think the problem is that there are two different right hinges, one for the advanced filtration system and one for without.  It looks like you have the one without and that is why you cann...]]></description>
                        <content:encoded><![CDATA[<p>I think the problem is that there are two different right hinges, one for the advanced filtration system and one for without.  It looks like you have the one without and that is why you cannot use the appropriate nut and are having issues.  I just looked at mine and it looks different than your picture.  See the link below.  you need to print part "RT" not "R".  It will work if your print the other right hinge part.</p><p><a href="https://www.printables.com/model/273426-hinged-lid-for-adding-mmu2s-to-original-prusa-encl" target="_blank" rel="noopener">https://www.printables.com/model/273426-hinged-lid-for-adding-mmu2s-to-original-prusa-encl</a></p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/assembly-and-troubleshooting/">Assembly and troubleshooting</category>                        <dc:creator>JBinFL</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/assembly-and-troubleshooting/hinged-lid-and-advanced-filtering-system/#post-717987</guid>
                        <link>https://forum.prusa3d.com/forum/assembly-and-troubleshooting/hinged-lid-and-advanced-filtering-system/#post-717074</link>
                        <pubDate>Tue, 23 Jul 2024 12:01:40 +0000</pubDate>
                        <description><![CDATA[I just attached the filtration sytem to the left sidewall to avoid interference with the hinged lid...]]></description>
                        <content:encoded><![CDATA[<p>I just attached the filtration sytem to the left sidewall to avoid interference with the hinged lid...</p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/assembly-and-troubleshooting/">Assembly and troubleshooting</category>                        <dc:creator>Dragonos</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/assembly-and-troubleshooting/hinged-lid-and-advanced-filtering-system/#post-717074</guid>
                        <title>Hinged Lid and Advanced Filtering system</title>
                        <link>https://forum.prusa3d.com/forum/assembly-and-troubleshooting/hinged-lid-and-advanced-filtering-system/#post-624402</link>
                        <pubDate>Sun, 23 Oct 2022 10:21:21 +0000</pubDate>
                        <description><![CDATA[Hello,today I assembled my advanced filtering system. It looks like the filtering system and the hinged lid addon are not fully compatible. In the instructions step 24 and 25 are not fully c...]]></description>
                        <content:encoded><![CDATA[<p>Hello,</p><p>today I assembled my advanced filtering system. It looks like the filtering system and the hinged lid addon are not fully compatible. In the instructions step 24 and 25 are not fully compatible if the hinged lid is installed.</p><p>So I changed the damper position and turned the one, that is in conflict with the hinged lid. To secure the damper I used a nut.</p><p>I'm a little bit disappointed because I thought the advanced filtering system offers me a chance to use it as a fan and to control the temperature inside. But this is not possible. Do you know if there is a fan planned for the enclosure?</p><p> </p><p>Installation of the advanced filtering system with mounted hinged lid:</p><p>Turned around the damper in the conflict position:</p><p><a href="https://forum.prusa3d.com/wp-content/uploads/2022/10/PXL_20221023_090237304.jpg"><img class="alignnone size-medium wp-image-146298" src="https://forum.prusa3d.com/wp-content/uploads/2022/10/PXL_20221023_090237304-600x500.jpg" alt="" width="600" height="500" /></a></p><p>Secure the damper with a nut:</p><p><a href="https://forum.prusa3d.com/wp-content/uploads/2022/10/PXL_20221023_090227531.jpg"><img class="alignnone size-medium wp-image-146300" src="https://forum.prusa3d.com/wp-content/uploads/2022/10/PXL_20221023_090227531-600x500.jpg" alt="" width="600" height="500" /></a></p><p>Installation is possible. The damper is a spacer between the parts.</p><p><a href="https://forum.prusa3d.com/wp-content/uploads/2022/10/PXL_20221023_090356875.MP_.jpg"><img class="alignnone size-medium wp-image-146299" src="https://forum.prusa3d.com/wp-content/uploads/2022/10/PXL_20221023_090356875.MP_-600x500.jpg" alt="" width="600" height="500" /></a> </p><p>Greetings from Germany,<br />Patrick</p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/assembly-and-troubleshooting/">Assembly and troubleshooting</category>                        <dc:creator>3Dino</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/assembly-and-troubleshooting/hinged-lid-and-advanced-filtering-system/#post-624402</guid>
