extruder slipped when enclosure is closed
Zfrenchy
(@zfrenchy)
Hi all,
When printing PETG with enclosure closed for keeping printer quieter, the extruder is skipping step, this is resolve quickly by opening doors and heat getting out.
Sorry I didn't look at the temperature ...
Anyone had this issue ?  If not, what is your enclosure temperature when printing PETG with doors closed ?
Veröffentlicht : 31/03/2024 10:39 pm
Eef
 Eef
(@eef)
RE: extruder slipped when enclosure is closed
In your showing off image I saw a thermometer?
Anyway, when I print I keep the door of enclosure open a bit. Temp is about 25-30 degrees Celsius.
It could be that the PETG starts slipping because of the temp.  I would check the adjustment of the tension of the extruder gears.
Veröffentlicht : 01/04/2024 9:00 pm
Walter Layher
(@walter-layher)
By chance was this slipping filament Prusament PETG Orange? I had the same problem once with this filament, not with other PETGs from Prusa or eSun, which are the most common ones I use. Since then I leave the doors of the enclosure a bit open when printing PETG. The temp inside the enclosure is around 30 °C with the doors opened a bit. I use this part to keep the doors in this position: https://www.printables.com/de/model/436274-enclosure-door-blocker
Veröffentlicht : 01/04/2024 9:15 pm
Zfrenchy
(@zfrenchy)
thanks for the answer, I will try when back at home.
Veröffentlicht : 01/04/2024 11:15 pm
