Converting temperature LCD module from C to fahrenheit
Skybox53
(@skybox53)
Hello All,
Has anyone converted the temperature module from C to fahrenheit.   I read a solder connection must be made on the circuit board from the C to F pad. But when looking at the board I don"t see the associated labels?  Was hoping I could get some assistance.
Thanks
Roger
Veröffentlicht : 15/03/2023 5:43 pm
RE: Converting temperature LCD module from C to fahrenheit
Hi Roger,
I have never tried this,
https://marlinfw.org/docs/gcode/M149.html
please give it a try and report back!
Joan
Veröffentlicht : 15/03/2023 6:01 pm
Skybox53
(@skybox53)
Hi Joan,
I went to the site but there are no instructions?  Maybe I'm missing something?
Roger
Veröffentlicht : 15/03/2023 6:29 pm
Hi Roger,
there appear to be three optional variables for the command
M149 [C] [F] [K]
[C]   Report in Degrees Centigrade
[F]    Report in Degrees Farenheight and
[K]   Report in degrees Kelvin
in your case try putting
M149 [F]
into the start Gcode
Regards Joan
Veröffentlicht : 16/03/2023 3:52 am
Skybox53
(@skybox53)
Thanks Joan but I may have been confusing in my original message.  My issue is the temperature and humidity module that’s bolted to the top left of the MK3S enclosure.  It’s not part of the printing system it simply gives the temperature and humidity reading of inside the enclosure.  Unfortunately it only displays celsius not fahrenheit.  That said, I read that it can be made to read Fahrenheit by bridging two solder points of the small circuit board inside.  My question to the group is how are these two points labeled so I can modify the board?
Thanks
Roger
Veröffentlicht : 16/03/2023 1:29 pm
Skybox53
(@skybox53)
Ok I’m going to answer my own question.  Attached is a picture showing how to put a solder bridge between two pads to convert from celsius to fahrenheit on the LCD module included with the Prusa MK3S enclosure.  See the circle showing the location.  Pay attention to how you disassemble.  Easy conversion.
Veröffentlicht : 19/03/2023 4:54 pm
skivvie, Jim, UA3DP und 3 weiteren Personen gefällt das
Beeguy
(@beeguy)
This is another issued model (KD-15-Y2)
Press IN on the 4 tabs . Note the solder pads near black dot. C/F. Bridge them for F.
Veröffentlicht : 29/12/2023 7:48 am
Du gefällt das
Turnpike
(@turnpike)
Or you could just buy these.
https://www.amazon.com/dp/B07GNMKYCZ?psc=1&ref=ppx_yo2ov_dt_b_product_details
Veröffentlicht : 30/01/2024 1:59 am
