z seam issues
Hi got my prusa mini+ a couple of days ago and trid my first petg print yesterday, it all looks good accept from one thing.
when it`s starting on a new layer it looks like it stops extruding for .2 of a second or something.
tried to change the z seam to the back side and the same issue appaerd there.
any ideas what it could be?
sliced in prusa slicer
filament: prusament petg
0.20 quality profile
tried to print this pre sliced whistle and it came out good
https://www.prusaprinters.org/prints/18985-little-beast-mini-whistle-3d-printing-test
BR Toftich
RE: z seam issues
the main problem is your nozzle is wear out or you got a bad one. the best solution is you have to change the nozzle, and the alternative solution (if you don't have a new nozzle) is you can reduce retraction length in prusaslicer from default 3.2mm to 2.0mm.
FYI : prusa mini+ use generic nozzle, not genuine E3D V6 nozzle.
RE: z seam issues
okay thank`s ,i will try that.
